[DRAFT] Evaluate the effectiveness of Kubernetes and Tensorflow on your cloud within an hour
Kubernetes and Tensorflow are two technologies that have been incubated by Google and are rapidly becoming industry standards. The first promises to increase server density for hosted applications, the latter is a leading platform for developing machine learning applications. Kubernetes boosts your data center (virtual or otherwise) and Tensorflow boosts your data scientists.
If your organisation is looking to evaluate either of those tools, it’s possible to do so easily from within your own cloud. This allows you to test the waters without moving any proprietary data outside of the firewall or arranging for any external services to be commissioned.
This post walks you through using the open source software tool Juju to facilitate a working evaluation of these technologies.
Step 1: Install management tools
The first step is to install the necessary software, in this case Juju to manage the infrastructure and kubectl for interacting directly with the Kubernetes cluster that will be provisioned.
Installation instructions for Linux
In Linux, the fastest way to install Juju is via snap:
sudo snap install kubectl --classic</code>
Installation instructions for macOS
On macOS, we can use Homebrew to install Juju:
brew install juju
brew install kubectl
Installation instructions for MS Windows
On MS Windows, we can use the installer provided by Canonical to install Juju and follow the instructions provided by the Kubernetes project to install kubectl:
If you run into any trouble, through documentation is provided at these the two URLs below. You are also welcome to
Step 2: Add your cloud
If you are running Juju behind the firewall, it may be necessary to tell it about your private cloud. Skip this step if you are using a public cloud provider.
Juju supports deployments using several organisational settings:
  • An ad hoc cloud made up of computers accessible via SSH
  • Bare metal servers managed by MAAS
  • An OpenStack instance, whether as a private cloud or a public offering
  • Clouds defined by VMware vSphere
Within a terminal window, run the juju add-cloud command:
Input/Output What we see on screen Explanation
Input
juju add-cloud --local
From the shell, we indicate that we want to add a cloud definition that will be accessible for all local controllers (--local).
Output
Cloud Types
  lxd
  maas
  manual
  openstack
  vsphere
Select cloud type:
Juju takes us through an interactive session where it will ask us for details such as usernames and passwords. The specific questions depend on the cloud type in question.
Note: if you would like specialist help for your situation, you are welcome to contact Canonical for personalised assistance.
Step 3: Add credentials
Once Juju has been installed, it needs to be authorised to act on your behalf. The juju autoload-credentials and juju add-credential commands assist here.
Detecting access credentials automatically
Juju can fetch authorisation credentials automatically for several cloud providers, include Amazon Web Services (AWS), Google Cloud Engine (GCE), private OpenStack clouds and LXD clusters. These providers store files within your home directory that can be detected by Juju.
Add access credentials manually
Juju supports dozens of cloud providers, including treating bare metal servers as a cloud.
juju add-credential <cloud>
Where <cloud> could be one of the following keywords:
Cloud Provider Juju <cloud> keyword
Amazon Web Services (AWS) aws
Microsoft Azure azure
Google Compute Engine (GCE) google
Joyent Triton joyent
Rackspace rackspace
Oracle Cloud Infrastructure oracle
CloudSigma cloudsigma
Step 4: Access help
If you get stuck at any stage, it can be useful to know where to turn to for help. Hopefully all readers will be able to skip this step!
You have several options available:
  • In the shell, run juju help <command>. Usually this documentation will get you unstuck.
  • On the web, we provide more thorough documentation
  • You’re welcome to ask questions here on Juju’s Discourse forum. Tag your questions with the Users category. The forum is actively monitored by Juju’s developers.
  • For those who prefer real-time communication, join the #juju channel on irc.freenode.net. Canonical staff who build Juju monitor this channel 24h and are happy to provide personal support on a best-effort basis.
  • If you believe that you’ve found an error with Juju, you’re very welcome to file a bug report. This will require you to create an account with Launchpad, Juju’s bug and release management system.
  • Commercial support is readily available. If you would like specialist help for your situation, please contact Canonical.
Step 5: Deploy a production-ready Kubernetes instance with a single line
Kubernetes is a complex software system that involves many moving parts. Juju takes care of that by providing a one line install by deploying a bundle:
Command to run
juju deploy canonical-kubernetes
Deploying canonical-kubernetes enables the Charmed Distribution of Kubernetes. This is a production-ready Kubernetes distribution excellent support for artificial intelligence (AI), machine learning (ML) and high-performance computing (HPC) workloads.
Output from Juju
Located bundle "cs:bundle/canonical-kubernetes-499"
Resolving charm: cs:~containers/easyrsa-235
Resolving charm: cs:~containers/etcd-415
Resolving charm: cs:~containers/flannel-404
Resolving charm: cs:~containers/kubeapi-load-balancer-628
Resolving charm: cs:~containers/kubernetes-master-654
Resolving charm: cs:~containers/kubernetes-worker-519
Executing changes:
- upload charm cs:~containers/easyrsa-235 for series bionic
- deploy application easyrsa on bionic using cs:~containers/easyrsa-235
  added resource easyrsa
- set annotations for easyrsa
- upload charm cs:~containers/etcd-415 for series bionic
- deploy application etcd on bionic using cs:~containers/etcd-415
  added resource etcd
  added resource snapshot
- set annotations for etcd
- upload charm cs:~containers/flannel-404 for series bionic
- deploy application flannel on bionic using cs:~containers/flannel-404
  added resource flannel-amd64
  added resource flannel-arm64
  added resource flannel-s390x
- set annotations for flannel
- upload charm cs:~containers/kubeapi-load-balancer-628 for series bionic
- deploy application kubeapi-load-balancer on bionic using cs:~containers/kubeapi-load-balancer-628
- expose kubeapi-load-balancer
- set annotations for kubeapi-load-balancer
- upload charm cs:~containers/kubernetes-master-654 for series bionic
- deploy application kubernetes-master on bionic using cs:~containers/kubernetes-master-654
  added resource cdk-addons
  added resource kube-apiserver
  added resource kube-controller-manager
  added resource kube-proxy
  added resource kube-scheduler
  added resource kubectl
- set annotations for kubernetes-master
- upload charm cs:~containers/kubernetes-worker-519 for series bionic
- deploy application kubernetes-worker on bionic using cs:~containers/kubernetes-worker-519
  added resource cni-amd64
  added resource cni-arm64
  added resource cni-s390x
  added resource kubelet
- expose kubernetes-worker
- set annotations for kubernetes-worker
- add relation kubernetes-master:kube-api-endpoint - kubeapi-load-balancer:apiserver
- add relation kubernetes-master:loadbalancer - kubeapi-load-balancer:loadbalancer
- add relation kubernetes-master:kube-control - kubernetes-worker:kube-control
- add relation kubernetes-master:certificates - easyrsa:client
- add relation etcd:certificates - easyrsa:client
- add relation kubernetes-master:etcd - etcd:db
- add relation kubernetes-worker:certificates - easyrsa:client
- add relation kubernetes-worker:kube-api-endpoint - kubeapi-load-balancer:website
- add relation kubeapi-load-balancer:certificates - easyrsa:client
- add relation flannel:etcd - etcd:db
- add relation flannel:cni - kubernetes-master:cni
- add relation flannel:cni - kubernetes-worker:cni
- add unit easyrsa/0 to new machine 0
- add unit etcd/0 to new machine 1
- add unit etcd/1 to new machine 2
- add unit etcd/2 to new machine 3
- add unit kubeapi-load-balancer/0 to new machine 4
- add unit kubernetes-master/0 to new machine 5
- add unit kubernetes-master/1 to new machine 6
- add unit kubernetes-worker/0 to new machine 7
- add unit kubernetes-worker/1 to new machine 8
- add unit kubernetes-worker/2 to new machine 9
Deploy of bundle completed.
This output details the steps that Juju intends to take on your behalf. The full deployment takes several minutes.
Step 6: Monitor the system
It’s often very useful to be able to get a sense of what’s actually happening in your cluster. Juju provides two main tools for this purpose: its status sub-command and the Juju GUI.
Getting status information from the command line
juju status
Output from Juju once Charmed Kubernetes has been successfully deployed. If you run juju status during the deployment, you’ll note that some of the applications are in the “blocked” and “waiting” state. Juju is working to install and configure all of the machines.
Model    Controller       Cloud/Region   Version      SLA          Timestamp
default  evaluate-k8s-tf  aws/us-west-2  2.7-beta1.1  unsupported  09:19:48+12:00
App                    Version  Status  Scale  Charm                  Store       Rev  OS      Notes
easyrsa                3.0.1    active      1  easyrsa                jujucharms  235  ubuntu
etcd                   3.2.10   active      3  etcd                   jujucharms  415  ubuntu
flannel                0.10.0   active      5  flannel                jujucharms  404  ubuntu
kubeapi-load-balancer  1.14.0   active      1  kubeapi-load-balancer  jujucharms  628  ubuntu  exposed
kubernetes-master      1.14.1   active      2  kubernetes-master      jujucharms  654  ubuntu
kubernetes-worker      1.14.1   active      3  kubernetes-worker      jujucharms  519  ubuntu  exposed
Unit                      Workload  Agent  Machine  Public address  Ports           Message
easyrsa/0*                active    idle   0        34.216.50.32                    Certificate Authority connected.
etcd/0                    active    idle   1        52.26.135.252   2379/tcp        Healthy with 3 known peers
etcd/1*                   active    idle   2        54.244.152.22   2379/tcp        Healthy with 3 known peers
etcd/2                    active    idle   3        34.209.200.17   2379/tcp        Healthy with 3 known peers
kubeapi-load-balancer/0*  active    idle   4        18.236.235.50   443/tcp         Loadbalancer ready.
kubernetes-master/0*      active    idle   5        54.148.34.194   6443/tcp        Kubernetes master running.
  flannel/3               active    idle            54.148.34.194                   Flannel subnet 10.1.39.1/24
kubernetes-master/1       active    idle   6        34.221.36.250   6443/tcp        Kubernetes master running.
  flannel/4               active    idle            34.221.36.250                   Flannel subnet 10.1.24.1/24
kubernetes-worker/0       active    idle   7        54.245.153.244  80/tcp,443/tcp  Kubernetes worker running.
  flannel/0*              active    idle            54.245.153.244                  Flannel subnet 10.1.19.1/24
kubernetes-worker/1*      active    idle   8        35.165.101.160  80/tcp,443/tcp  Kubernetes worker running.
  flannel/1               active    idle            35.165.101.160                  Flannel subnet 10.1.66.1/24
kubernetes-worker/2       active    idle   9        34.212.131.49   80/tcp,443/tcp  Kubernetes worker running.
  flannel/2               active    idle            34.212.131.49                   Flannel subnet 10.1.68.1/24
Machine  State    DNS             Inst id              Series  AZ          Message
0        started  34.216.50.32    i-0fc17714927269d2d  bionic  us-west-2a  running
1        started  52.26.135.252   i-0502f998d448a7d7d  bionic  us-west-2a  running
2        started  54.244.152.22   i-05a4c46bfeeb2aefb  bionic  us-west-2b  running
3        started  34.209.200.17   i-09fa93f8c5a397984  bionic  us-west-2c  running
4        started  18.236.235.50   i-0d5329c014539a0ec  bionic  us-west-2c  running
5        started  54.148.34.194   i-00918ab6392acd113  bionic  us-west-2a  running
6        started  34.221.36.250   i-014c611ece25eec0e  bionic  us-west-2b  running
7        started  54.245.153.244  i-069086c871b70d1f9  bionic  us-west-2a  running
8        started  35.165.101.160  i-0a5d6de45d86efe26  bionic  us-west-2b  running
9        started  34.212.131.49   i-0f353dd1a7160469f  bionic  us-west-2c  running
Accessing Juju status information via the web
An alternative for people who prefer visual output is Juju’s interactive web interface. To begin, ask Juju for the URL and credentials for connecting to the GUI.
juju gui
This command asks Juju for the URL and access details for the GUI. It responds:
GUI 2.14.0 for model "admin/default" is enabled at:
  https://10.0.0.42:17070/gui/u/admin/default
Your login credential is:
  username: admin
  password: 5098c1a4ee3c1b791e825b85ea503e2c
Visiting this URL will probably raise a security warning in your browser. Juju has established its own certificate authority that the browser doesn’t know about. You should accept the warnings.
Once logged in, we can inspect the model’s status by clicking on the status tab. This will automatically refresh over time.
Step 7: Tell kubectl about your new Kubernetes
mkdir ~/.kube
juju scp kubernetes-master/0:config ~/.kube/config
We’re now able to test our local machine’s ability to connect:
kubectl  cluster-info
Kubernetes master is running at https://13.211.252.172:443
Heapster is running at https://13.211.252.172:443/api/v1/namespaces/kube-system/services/heapster/proxy
CoreDNS is running at https://13.211.252.172:443/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
Metrics-server is running at https://13.211.252.172:443/api/v1/namespaces/kube-system/services/https:metrics-server:/proxy
Grafana is running at https://13.211.252.172:443/api/v1/namespaces/kube-system/services/monitoring-grafana/proxy
InfluxDB is running at https://13.211.252.172:443/api/v1/namespaces/kube-system/services/monitoring-influxdb:http/proxy
To further debug and diagnose cluster problems, use 'kubectl cluster-info dump'.
Step 8: Add a storage class
Using integrator charms
Azure, AWS and GCE have specialist charms that increase Juju’s affinity with the particular cloud APIS.
In Amazon AWS, the process looks like this:
juju deploy --to 0 aws-integrator
juju relate aws-integrator kubernetes-master
juju relate aws-integrator kubernetes-worker
juju trust aws-integrator
Manually defining a storage class
Without the integrator charms, we can use kubectl directly.
kubectl create -f - <<STORAGE
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
  annotations:
     storageclass.kubernetes.io/is-default-class: "true"
ovisioner: kubernetes.io/aws-ebs
parameters:
  type: gp2
STORAGE
storageclass.storage.k8s.io/default created
This storage class definition is specific to AWS. The Kubernetes documentation provides detailed information about defining storage classes for specific cloud providers.
Step 9: Enabled Juju to drive the Charmed Kubernetes we have created
We’re now in a position to create a Kubernetes cluster!
juju add-k8s k8s-tf --storage=default --region=aws/ap-southeast-2
k8s substrate "aws/ap-southeast-2" added as cloud "k8s-tf" with storage provisioned
by the existing "default" storage class
operator storage provisioned by the workload storage class.
Hurray! Juju knows about Charmed Kubernetes! We’ve called it k8s-tf
Step 10: Deploy Tensorflow on Kubernetes
Here is a view on on our current state:
  • A cluster of machines being managed by Juju in the cloud, called evaluate-k8s-tf by Juju
  • A Charmed Kubernetes instance deployed onto our cluster, called k8s-tf in Juju
We now want to install Tensorflow on top of k8s-tf. To do that, we need to add a Juju “model”. Model is the term used by the Juju community, whereas others may use the term “stack”, “project” or “product”. A Juju model encapsulates all of the cloud components that are necessary as part of a Software as a Service offering.
juju add-model tf k8s-tf
Output from juju add-model tf-k8s-tf
Added 'tf' model on k8s-datascience with credential 'admin' for user 'admin'
Add a storage pool:
juju create-storage-pool k8s-ebs kubernetes storage-class=default
We’re now in a position where we can deploy kubeflow on top of our Kubernetes cluster.
juju deploy kubeflow
Output from juju deploy kubeflow
Located bundle "cs:bundle/kubeflow-46"
Resolving charm: cs:~kubeflow-charmers/kubeflow-ambassador
Resolving charm: cs:~kubeflow-charmers/kubeflow-jupyterhub
Resolving charm: cs:~kubeflow-charmers/kubeflow-pytorch-operator
Resolving charm: cs:~kubeflow-charmers/kubeflow-seldon-api-frontend
Resolving charm: cs:~kubeflow-charmers/kubeflow-seldon-cluster-manager
Resolving charm: cs:~kubeflow-charmers/kubeflow-tf-job-dashboard
Resolving charm: cs:~kubeflow-charmers/kubeflow-tf-job-operator
Resolving charm: cs:~kubeflow-charmers/redis-k8s
Executing changes:
- upload charm cs:~kubeflow-charmers/kubeflow-ambassador-46 for series kubernetes
- deploy application kubeflow-ambassador with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-ambassador-46
  added resource ambassador-image
- set annotations for kubeflow-ambassador
- upload charm cs:~kubeflow-charmers/kubeflow-jupyterhub-42 for series kubernetes
- deploy application kubeflow-jupyterhub with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-jupyterhub-42
  added resource jupyterhub-image
- set annotations for kubeflow-jupyterhub
- upload charm cs:~kubeflow-charmers/kubeflow-pytorch-operator-45 for series kubernetes
- deploy application kubeflow-pytorch-operator with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-pytorch-operator-45
  added resource pytorch-operator-image
- set annotations for kubeflow-pytorch-operator
- upload charm cs:~kubeflow-charmers/kubeflow-seldon-api-frontend-31 for series kubernetes
- deploy application kubeflow-seldon-api-frontend with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-seldon-api-frontend-31
  added resource api-frontend-image
- set annotations for kubeflow-seldon-api-frontend
- upload charm cs:~kubeflow-charmers/kubeflow-seldon-cluster-manager-29 for series kubernetes
- deploy application kubeflow-seldon-cluster-manager with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-seldon-cluster-manager-29
  added resource cluster-manager-image
- set annotations for kubeflow-seldon-cluster-manager
- upload charm cs:~kubeflow-charmers/kubeflow-tf-job-dashboard-44 for series kubernetes
- deploy application kubeflow-tf-job-dashboard with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-tf-job-dashboard-44
  added resource tf-operator-image
- set annotations for kubeflow-tf-job-dashboard
- upload charm cs:~kubeflow-charmers/kubeflow-tf-job-operator-43 for series kubernetes
- deploy application kubeflow-tf-job-operator with 1 unit on kubernetes using cs:~kubeflow-charmers/kubeflow-tf-job-operator-43
- set annotations for kubeflow-tf-job-operator
- upload charm cs:~kubeflow-charmers/redis-k8s-6 for series kubernetes
- deploy application redis with 1 unit on kubernetes using cs:~kubeflow-charmers/redis-k8s-6
  added resource redis-image
- set annotations for redis
- add relation kubeflow-tf-job-dashboard - kubeflow-ambassador
- add relation kubeflow-jupyterhub - kubeflow-ambassador
- add relation kubeflow-seldon-api-frontend - redis
- add relation kubeflow-seldon-cluster-manager - redis
