Does Canonical support Masakari ?
I believe so: masakari | Juju, if this is what you mean? Though it says supported by ‘openstack-charmers’ which I guess is not necessarily just Canonical?
Does anyone know if Maskari supports TLS endpoints.
I’ve just started doing some testing but noticed that even though I’m relating to Vault, the Openstack endpoint uses HTTP
root@maas-01:~# juju status masakari --relations
openstack-lab-devzero-home juju.lab.devzero.home maas.lab.devzero.home/default 2.8.7 unsupported 17:29:05Z
App Version Status Scale Charm Store Channel Rev OS Message
masakari 9.0.0 active 3 masakari charmstore 10 ubuntu Unit is ready
masakari-hacluster active 3 hacluster charmstore 76 ubuntu Unit is ready and clustered
masakari-mysql-router 8.0.25 active 3 mysql-router charmstore 8 ubuntu Unit is ready
masakari/0* active idle 0/lxd/8 192.168.51.22 15868/tcp Unit is ready
masakari-hacluster/0* active idle 192.168.51.22 Unit is ready and clustered
masakari-mysql-router/0* active idle 192.168.51.22 Unit is ready
masakari/1 active idle 1/lxd/8 192.168.51.54 15868/tcp Unit is ready
masakari-hacluster/2 active idle 192.168.51.54 Unit is ready and clustered
masakari-mysql-router/2 active idle 192.168.51.54 Unit is ready
masakari/2 active idle 2/lxd/8 192.168.51.65 15868/tcp Unit is ready
masakari-hacluster/1 active idle 192.168.51.65 Unit is ready and clustered
masakari-mysql-router/1 active idle 192.168.51.65 Unit is ready
0 started 192.168.51.16 saving-trout focal NC Deployed
0/lxd/8 started 192.168.51.22 juju-77700e-0-lxd-8 focal NC Container started
1 started 192.168.51.39 superb-moose focal NC Deployed
1/lxd/8 started 192.168.51.54 juju-77700e-1-lxd-8 focal NC Container started
2 started 192.168.51.45 good-lamb focal NC Deployed
2/lxd/8 started 192.168.51.65 juju-77700e-2-lxd-8 focal NC Container started
keystone:identity-service masakari:identity-service keystone regular
masakari-hacluster:ha masakari:ha hacluster subordinate
masakari-hacluster:hanode masakari-hacluster:hanode hacluster peer
masakari-mysql-router:shared-db masakari:shared-db mysql-shared subordinate
masakari:cluster masakari:cluster openstack-ha peer
mysql-innodb-cluster:db-router masakari-mysql-router:db-router mysql-router regular
pacemaker-remote:pacemaker-remote masakari-hacluster:pacemaker-remote pacemaker-remote regular
rabbitmq-server:amqp masakari:amqp rabbitmq regular
vault:certificates masakari:certificates tls-certificates regular
root@maas-01:~#
root@maas-01:~#
root@maas-01:~# openstack endpoint list| grep instance-ha
| 052e9cfd2e6d4af9829c1fd13759f835 | RegionOne | masakari | instance-ha | True | public | http://masakari.lab.devzero.home:15868/v1/%(tenant_id)s |
| 38b870694ac0457db9dcc6bef4cb99f3 | RegionOne | masakari | instance-ha | True | admin | http://masakari.lab.devzero.home:15868/v1/%(tenant_id)s |
| 675b7b2476254f3389e2a26bd1172c71 | RegionOne | masakari | instance-ha | True | internal | http://masakari.lab.devzero.home:15868/v1/%(tenant_id)s |
The endpoint should be using HTTPS. Perhaps the charm failed to restart something. Could you file a bug on this?
Can you give more detail on what sort of information you are looking for? That being said here are a few points:
- Canonical makes available software packages (such as Masakari) in the default Ubuntu package archives as well as backports for supported Ubuntu TLS releases via the Ubuntu Cloud Archive.
- Canonical also creates and supports Juju charms that provision Masakari nodes for use in the Charmed OpenStack project, whose usage is documented in the OpenStack Charms Deployment Guide.
