I’ve been experimenting with developing and deploying charms on an ARM box (it’s an M1 Mac, but I think that what I write here would apply to any ARM based Chromebook, or a theoretical jump box in an ARM cloud).
Has anyone else been doing so? What has your experience been like? (I’ll leave my own answers to these questions below.)
Multipass installed on the Macs so that I can easily spin up Ubuntu VMs.
Ubuntu Server installed on a small form factor Amd64 based computer, which I access over my local network (or via a secure tunnel that I can use while traveling).
An lxd cluster on the Amd64 box, which I have access to from the lxc client on my Arm boxen.
I’ve found myself working more from a remote session on the Amd64 server than locally on one of the Macs. This is a pretty typical DevOps setup, and part of why I like it is simply the convenience of working from a byobu session on the server as I switch between my laptop and desktop. But there are some papercuts that prevent me from being able to change my workflow if I wanted to.
What works well:
The juju client generally works well, both run natively from homebrew, and run in a multipass vm. I do have to pass --constraints arch=amd64 when bootstrapping an AWS controller, but that’s a one time inconvenience. After that, I can deploy and operate a cloud without issue.
Registering, publishing, and releasing charms with charmcraft works well. (Again, this applies to both the homebrew version and the snap running in a vm.)
Multipass & LXD work well, just in general! I think that these are two of Canonical’s best projects, and I really enjoy using them.
What doesn’t work well:
charmcraft pack. It builds the Arm64 version of the charm, which I can’t then deploy to AWS, or my lxd cluster.
juju deploy to the Amd64 lxd cluster from a client on an Arm box. The Juju CLI sees a mismatch between the architecture on the Ubuntu server and the Arm box that is running the client, and I wasn’t able to fix this with constraints. (I think that it’s because the lxd cluster looks like a local cluster to Juju, which invokes a separate check.)
