Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
How to configure the hostname
This guide provides instructions for configuring the external hostname of the Discourse charm.
Deploy and relate nginx-ingress-integrator charm.
juju deploy nginx-ingress-integrator
juju trust nginx-ingress-integrator --scope cluster # if RBAC is enabled
juju relate discourse-k8s nginx-ingress-integrator
Configure hostname
This charm exposes the external_hostname configuration option to specify the external hostname of the application.
To configure a different hostname for Discourse, you can configure the ingress hostname through the discourse-k8s configuration.
juju config discourse-k8s external_hostname=<desired-hostname>
The output of juju status should look similar to the following:
tutorial mk8s microk8s/localhost 2.9.44 unsupported 18:19:34-04:00
discourse-k8s 2.8.14 active 1 discourse-k8s 41 <discourse-ip> no
nginx-ingress-integrator 25.3.0 active 1 nginx-ingress-integrator latest/stable 81 <ingress-ip> no Ingress IP(s): 127.0.0.1, Service IP(s): <ingress-svc-ip>
postgresql-k8s 14.9 active 1 postgresql-k8s 14/edge 145 <postgres-ip> no Primary
redis-k8s 7.0.4 active 1 redis-k8s latest/edge 26 <redis-ip> no
discourse-k8s/0* active idle <discourse-ip>
nginx-ingress-integrator/0* active idle <ingress-ip> Ingress IP(s): 127.0.0.1, Service IP(s): <ingress-svc-ip>
postgresql-k8s/0* active idle <postgres-ip> Primary
redis-k8s/0* active idle <redis-ip>
Note the Service IP(s): next to nginx-ingress-integrator charm’s Status output.
Test the ingress by sending a GET request to the service with Host headers.
curl -H "Host: <desired-hostname>" http://<ingress-svc-ip>
