discourse-k8s docs: How to configure SMTP
Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
To configure Discourse’s SMTP you’ll have to set the following configuration options with the appropriate values for your SMTP server by running juju config [charm_name] [configuration]=[value].
Set smtp_addressto the SMTP server IP or hostname, smtp_port for the SMTP sever port if different from the default and smtp_domain to set the sender domain address.
If authentication is needed, smtp_authentication will need to be set to the appropriate authentication method, valid values are none, login, plain, cram_md5. The credentials can be set with smtp_usernameand smtp_password.
You can enable/disable SMTP over TLS with the smtp_force_tls option and handle starttls with smtp_enable_start_tls.
If needed, the verification of the SSL certs can be turned on and off with smtp_openssl_verify_mode.
For more details on the configuration options and their default values see the configuration reference.
