Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
How to configure SAML
To configure Discourse’s SAML integration you’ll have to set the following configuration options with the appropriate values for your SAML server by running juju config [charm_name] [configuration]=[value].
If you wish to force the login to go through SAML, enable force_saml_login.
The groups to be synced from the provider can be defined in saml_sync_groups as a comma-separated list of values.
In order to implement the relation, Discourse has to be related with the saml-integrator:
juju deploy saml-integrator --channel=edge
# Set the SAML integrator configs
juju config saml-integrator metadata_url=https://login.staging.ubuntu.com/saml/metadata
juju config saml-integrator entity_id=https://login.staging.ubuntu.com
juju integrate discourse-k8s saml-integrator
For more details on the configuration options and their default values see the configuration reference.
