Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
External access required by the Charm
Depending on the configuration of the charm, the following external accesses are needed:
- Access to the PostgreSQL database (mandatory).
- Access to the S3 server is S3 is configured in the charm.
- Access to GitHub to download Promtail if the logging interface is used in the charm.
If the option “external system avatars enabled” is enabled in the admin, access to https://avatars.discourse.org is necessary.
Besides that, other services, like link previews and installing themes from a git repository
may need access to external sites to work, so allowing internet access to the Discourse instance is
recommended. In restricted environments, the model-config options juju-http-proxy, juju-https-proxy
and juju-no-proxy can be used to set up a proxy for Discourse,
see Using proxies with Charmed Kubernetes for
more information.
