SMTP configuration
To configure Discourse’s SMTP you’ll have to set the following configuration options with the appropriate values for your SMTP server by running juju config [charm_name] [configuration]=[value].
Set smtp_addressto the SMTP server IP or hostname, smtp_port for the SMTP sever port if different from the default and smtp_domain to set the sender domain address.
If authentication is needed, smtp_authentication will need to be set to the appropriate authentication method, valid values are none, login, plain, cram_md5. The credentials can be set with smtp_usernameand smtp_password.
If needed, the verification of the SSL certs can be turned on and off with smtp_openssl_verify_mode.
For more details on the configuration options and their default values see the configuration reference.
