SAML configuration
To configure Discourse’s SAML integration you’ll have to set the following configuration options with the appropriate values for your SAML server by running juju config [charm_name] [configuration]=[value].
The SAML URL needs to be scpecified in saml_target_url. If you wish to force the login to go through SAML, enable force_saml_login.
The groups to be synced from the provider can be defined in saml_sync_groups as a comma-separated list of values.
For more details on the configuration options and their default values see the configuration reference.
