Hostname configuration
This charm exposes the external_hostname
configuration option to specify the external hostname of the application.
To expose the application it is recommended to set that configuration option and deploy and relate the Nginx Ingress Integrator Operator, that will be automatically configured with the values provided by the charm.
Assuming Discourse is already up and running as discourse-k8s
, you’ll need to run the following commands:
# Configure the external hostname
juju config discourse-k8s external_hostname=discourse.local
# Deploy and relate the Nginx Ingress Integrator charm
juju deploy nginx-ingress-integrator
juju trust nginx-ingress-integrator --scope cluster # if RBAC is enabled
juju relate nginx-ingress-integrator discourse-k8s
For more details on the configuration options and their default values see the configuration reference.
