I’m not sure everyone knows what this is, would you mind expanding? Also, I found the config link you gave to be very straight forward and informative. Can you elaborate further on what you feel it is missing?
A best practice reactive code example that covers how to deal with a restart/reload of a custom service to deal with when configuration changes vs installation. Something I have some problems getting my head around a good way to manage with a good strategy. Dealing with install/start/restart/reload is quite a common thing for many services - yet there are no good examples in the documentation for this yet. Personally, I had to roam around in your repos to find examples and I’m not super happy about those I found.
The comments in the code example are the best - but I would really be helped from this being covered more in-depth in the documentation rather than in the comments in the example code?
Many other concepts have a dedicated chapter in the docs and how config works is a fundamental piece of juju I would say which also lowers the bar for entry.
I’d say there’s a tutorial that needs writing that couples the Charmhelpers API with some practical examples.
I’m almost at the point where I’d like to write one myself for a charm I’m currently ‘almost’ done authoring, but it’s the little detailed Python syntax bits that’s slowing me down from getting it done, and I’m reluctant to ask what I see as basic Python questions here, where I perceive the expectation is that a minimum knowledge level for charm authoring is just a touch above my own Python skills
