Hi All,
I am following below article to setup charmed kubeflow in my local environment
On deploying it fails as shown in below logs. Looks like there is a dependency for Katib-db charm with the juju version. I was using juju 3.1 for the whole process.
mm321:~$ sudo sysctl fs.inotify.max_user_instances=1280
sudo sysctl fs.inotify.max_user_watches=655360
fs.inotify.max_user_instances = 1280
fs.inotify.max_user_watches = 655360
mm321:~$ juju deploy kubeflow --trust --channel=1.8/stable
Located bundle "kubeflow" in charm-hub, revision 414
Located charm "admission-webhook" in charm-hub, channel 1.8/stable
Located charm "argo-controller" in charm-hub, channel 3.3.10/stable
Located charm "dex-auth" in charm-hub, channel 2.36/stable
Located charm "envoy" in charm-hub, channel 2.0/stable
Located charm "istio-gateway" in charm-hub, channel 1.17/stable
Located charm "istio-pilot" in charm-hub, channel 1.17/stable
Located charm "jupyter-controller" in charm-hub, channel 1.8/stable
Located charm "jupyter-ui" in charm-hub, channel 1.8/stable
Located charm "katib-controller" in charm-hub, channel 0.16/stable
Located charm "mysql-k8s" in charm-hub, channel 8.0/stable
Located charm "katib-db-manager" in charm-hub, channel 0.16/stable
Located charm "katib-ui" in charm-hub, channel 0.16/stable
Located charm "kfp-api" in charm-hub, channel 2.0/stable
Located charm "kfp-metadata-writer" in charm-hub, channel 2.0/stable
Located charm "kfp-persistence" in charm-hub, channel 2.0/stable
Located charm "kfp-profile-controller" in charm-hub, channel 2.0/stable
Located charm "kfp-schedwf" in charm-hub, channel 2.0/stable
Located charm "kfp-ui" in charm-hub, channel 2.0/stable
Located charm "kfp-viewer" in charm-hub, channel 2.0/stable
Located charm "kfp-viz" in charm-hub, channel 2.0/stable
Located charm "knative-eventing" in charm-hub, channel 1.10/stable
Located charm "knative-operator" in charm-hub, channel 1.10/stable
Located charm "knative-serving" in charm-hub, channel 1.10/stable
Located charm "kserve-controller" in charm-hub, channel 0.11/stable
Located charm "kubeflow-dashboard" in charm-hub, channel 1.8/stable
Located charm "kubeflow-profiles" in charm-hub, channel 1.8/stable
Located charm "kubeflow-roles" in charm-hub, channel 1.8/stable
Located charm "kubeflow-volumes" in charm-hub, channel 1.8/stable
Located charm "metacontroller-operator" in charm-hub, channel 3.0/stable
Located charm "minio" in charm-hub, channel ckf-1.8/stable
Located charm "mlmd" in charm-hub, channel 1.14/stable
Located charm "oidc-gatekeeper" in charm-hub, channel ckf-1.8/stable
Located charm "pvcviewer-operator" in charm-hub, channel 1.8/stable
Located charm "seldon-core" in charm-hub, channel 1.17/stable
Located charm "tensorboard-controller" in charm-hub, channel 1.8/stable
Located charm "tensorboards-web-app" in charm-hub, channel 1.8/stable
Located charm "training-operator" in charm-hub, channel 1.7/stable
Executing changes:
- upload charm admission-webhook from charm-hub from channel 1.8/stable with architecture=amd64
- deploy application admission-webhook from charm-hub with 1 unit with 1.8/stable
added resource oci-image
- upload charm argo-controller from charm-hub from channel 3.3.10/stable with architecture=amd64
- deploy application argo-controller from charm-hub with 1 unit with 3.3.10/stable
- upload charm dex-auth from charm-hub from channel 2.36/stable with architecture=amd64
- deploy application dex-auth from charm-hub with 1 unit with 2.36/stable
- upload charm envoy from charm-hub from channel 2.0/stable with architecture=amd64
- deploy application envoy from charm-hub with 1 unit with 2.0/stable
- upload charm istio-gateway from charm-hub from channel 1.17/stable with architecture=amd64
- deploy application istio-ingressgateway from charm-hub with 1 unit with 1.17/stable using istio-gateway
- upload charm istio-pilot from charm-hub from channel 1.17/stable with architecture=amd64
- deploy application istio-pilot from charm-hub with 1 unit with 1.17/stable
- upload charm jupyter-controller from charm-hub from channel 1.8/stable with architecture=amd64
- deploy application jupyter-controller from charm-hub with 1 unit with 1.8/stable
- upload charm jupyter-ui from charm-hub from channel 1.8/stable with architecture=amd64
- deploy application jupyter-ui from charm-hub with 1 unit with 1.8/stable
- upload charm katib-controller from charm-hub from channel 0.16/stable with architecture=amd64
- deploy application katib-controller from charm-hub with 1 unit with 0.16/stable
- upload charm mysql-k8s from charm-hub from channel 8.0/stable with architecture=amd64
- deploy application katib-db from charm-hub with 1 unit with 8.0/stable using mysql-k8s
ERROR cannot deploy bundle: cannot deploy application "katib-db": Charm feature requirements cannot be met:
- charm requires at least one of the following:
- charm requires all of the following:
- charm requires feature "juju" (version < 3.0.0) but model currently supports version 3.1.8
- charm requires feature "juju" (version >= 3.4.3) but model currently supports version 3.1.8
- charm requires feature "juju" (version >= 3.5.2) but model currently supports version 3.1.8
Feature descriptions:
- "juju": the version of Juju used by the model
For additional information please see: https://juju.is/docs/olm/supported-features
