Deploying COS - error on prometheus-k8s channel
Hi everyone,
I deployed COS yesterday without a problem, today - having this issue
juju deploy cos-lite --trust
Located bundle "cos-lite" in charm-hub, revision 11
Located charm "alertmanager-k8s" in charm-hub, channel 1/stable
Located charm "catalogue-k8s" in charm-hub, channel 1/stable
Located charm "grafana-k8s" in charm-hub, channel 1/stable
Located charm "loki-k8s" in charm-hub, channel 1/stable
ERROR cannot deploy bundle: cannot resolve charm or bundle "prometheus-k8s": selecting releases: charm or bundle not found for channel "stable", base "amd64"
available releases are:
  channel "1/candidate": available bases are: ubuntu@20.04
  channel "1/beta": available bases are: ubuntu@20.04
  channel "1/edge": available bases are: ubuntu@20.04
  channel "2/edge": available bases are: ubuntu@24.04
am I the only one?
We are having the same issue. Have you found a solution yet?
We were able to resolve this by adding in an overlay to direct to the channel 1/stable directly rather than just stable.
That seems to have worked for us.
I have same issue
I ended up rendereing my own yaml and point prometheus to channel: 2/edge which seems to be the latest version, so it should look like the below:
  prometheus:
    charm: prometheus-k8s
    scale: 1
    trust: true
    channel: 2/edge
Just wanted to mention, 2/* is the dev branch. It will only have edge releases and will not get stable releases until October. 1/* is the current stable release.
