Hej,
had problems deploying openstack bundle-70, worked my way back to that it seems to be an issue when deploying with focal as series.
Im running a MAAS environment, and deployed cs:mongodb-57 on the same host, if --series=bionic is used, the deployment works fine. If --series=focal, then the deployment ‘works’ on the host (Deployed), but juju keeps "waiting
ats@kmaas:~$ juju status
testmod kmv2 KMloud/default 2.7.1 unsupported 15:30:10+01:00
mongodb waiting 0/1 mongodb jujucharms 57 ubuntu
mongodb/2 waiting allocating 4 XYZ.14 waiting for machine
4 pending XYZ.14 idrac-ghzfk03 focal default Deployed
As juju isn’t really ready, manual ssh to the host XYZ.14 is the only thing that works.
Once connected, the only hint is that in /var/log/cloud-init-output.log
----begin
- ln -s 2.7.1-focal-amd64 /var/lib/juju/tools/machine-4
- echo Starting Juju machine agent (service jujud-machine-4)
Starting Juju machine agent (service jujud-machine-4) - mkdir -p /lib/systemd/system/jujud-machine-4
- cat
- chmod 0755 /lib/systemd/system/jujud-machine-4/exec-start.sh
- cat
- /bin/systemctl link /lib/systemd/system/jujud-machine-4/jujud-machine-4.service
Created symlink /etc/systemd/system/jujud-machine-4.service → /lib/systemd/system/jujud-machine-4/jujud-machine-4.service. - /bin/systemctl daemon-reload
- /bin/systemctl enable /lib/systemd/system/jujud-machine-4/jujud-machine-4.service
Created symlink /etc/systemd/system/multi-user.target.wants/jujud-machine-4.service → /lib/systemd/system/jujud-machine-4/jujud-machine-4.service. - /bin/systemctl start jujud-machine-4.service
Failed to start jujud-machine-4.service: Unit jujud-machine-4.service not found.
Cloud-init v. 20.3-2-g371b392c-0ubuntu1~20.04.1 running ‘modules:final’ at Tue, 01 Dec 2020 12:48:05 +0000. Up 138.92 seconds.
2020-12-01 12:48:41,723 - cc_scripts_user.py[WARNING]: Failed to run module scripts-user (scripts in /var/lib/cloud/instance/scripts)
2020-12-01 12:48:41,727 - util.py[WARNING]: Running module scripts-user (<module ‘cloudinit.config.cc_scripts_user’ from '/usr/lib/python3/dist-pac
Cloud-init v. 20.3-2-g371b392c-0ubuntu1~20.04.1 finished at Tue, 01 Dec 2020 12:48:41 +0000. Datasource DataSourceMAAS [http://194.47.151.84:5240/M
—end
But I cant decode that information, did it fail to download something? Something that’s missing?
As it works for bionc on the same host, I kind of ruled out MAAS host config messing things up (but failure is always an option right?).
Any hints, or tips on what could cause this problem?
BR/Patrik
