This part of the tutorial focuses on deploying PostgreSQL and Redis charms, which Superset requires to function.
Deploy a database
Charmed Superset relies on an external Charmed PostgreSQL database for storing application metadata such as users, dashboard definitions and logs. Deploy it as follows:
juju deploy postgresql-k8s --trust
You can check the deployment was successful by running juju status. You should expect an output like this:
superset-model superset-controller microk8s/localhost 3.5.3 unsupported 10:48:10+01:00
postgresql-k8s waiting 0/1 postgresql-k8s 14/stable 381 no installing agent
postgresql-k8s/0 waiting allocating installing agent
The database deployment may take some time, approximately 10 minutes, to complete. After that, all Juju components should be in active status.
Deploy a cache and message queue
Charmed Superset relies on an external Charmed Redis deployment, which acts as both a cache and message queue for Superset Celery workers. Deploy it as follows:
juju deploy redis-k8s --channel=edge
Check the deployment with juju status --watch 2s, with focus on the redis-k8s application and redis-k8s/0 unit. The deployment is completed once all units reach the active status:
superset-model superset-controller microk8s/localhost 3.5.3 unsupported 10:51:29+01:00
postgresql-k8s 14.12 active 1 postgresql-k8s 14/stable 381 10.152.183.243 no
redis-k8s 7.2.5 active 1 redis-k8s latest/edge 36 10.152.183.182 no
postgresql-k8s/0* active idle 10.1.255.10 Primary
redis-k8s/0* active idle 10.1.255.21
See next: Deploy Charmed Superset
