For using an AWS CDK for our OSM deployment we will need to follow these steps:
Create an AWS controller with juju:
juju bootstrap aws aws-k8s
We’ll deploy Kubernetes using the ‘kubernetes-core’ bundle, which will give us a minimalist cluster (Subsitute kubernetes-core with kubernetes for a complete Kubernetes). We’ll add the integrator charm to the mix by means of an overlay bundle that we’ll store in file k8s-aws-overlay.yaml:
applications:
aws-integrator:
charm: cs:~containers/aws-integrator
num_units: 1
relations:
- ['aws-integrator', 'kubernetes-master']
- ['aws-integrator', 'kubernetes-worker']
We can now deploy the cluster like so:
juju deploy charmed-kubernetes --overlay k8s-aws-overlay.yaml
juju trust aws-integrator
Now we have to grab the config file from the kubernetes-master pod and install kubectl:
mkdir ~/.kube
juju scp kubernetes-master/0:config ~/.kube/config
sudo snap install kubectl --classic
Once kubectl is installed we will have to setup storage with the following script:
#!/bin/bash
# create a storage class using the `kubernetes.io/aws-ebs` provisioner
kubectl create -f - <<EOY
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: kubernetes.io/aws-ebs
parameters:
type: gp2
EOY
# create a persistent volume claim using that storage class
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 100Mi
storageClassName: ebs-1
EOY
# create the busybox pod with a volume using that PVC:
apiVersion: v1
kind: Pod
metadata:
namespace: default
spec:
containers:
- image: busybox
command:
- sleep
- "3600"
imagePullPolicy: IfNotPresent
volumeMounts:
- mountPath: "/pv"
restartPolicy: Always
volumes:
- name: testvolume
persistentVolumeClaim:
claimName: testclaim
EOY
Once the storage is setup we can add-k8s and bootstrap a controller on it, in we will put our aws region on which the k8s is deployed.
cat .kube/config | juju add-k8s k8s-cloud --local --region=aws/<region>
juju bootstrap k8s-cloud
Once the bootstrap has been executed we can continue with the rest of the installation steps for OSM like usual.
