The Charmed Distribution of OSM (AWS)
Welcome to The Charmed Distribution of OSM!
The objective of this page is to give an overview of the first steps to get up and running with HA version of OSM.
User Guide
The installation process is very straight forward, and will help you in the process of installing OSM in AWS
Steps
- Bootstrap AWS Cloud
- Deploy CDK and OSM-VCA on AWS
- Boostrap CDK Cloud
- Deploy OSM
Bootstrap AWS Cloud
First of all, in your local machine, you should have juju installed.
AWS Credentials
Next step is to add the credentials of your AWS account.
juju add-credential aws
# Output
Enter credential name: osm-ha-credential
Using auth-type "access-key".
Enter access-key: XXXXXXXXXXXXXXXXX
Enter secret-key:
Credential "osm-ha-credential" added locally for cloud "aws".
Bootstrap controller
Once the credentials are added, it’s time to bootstrap a juju controller into AWS.
juju bootstrap aws aws-osm-ha --credential osm-ha-credential
This section will present the steps to deploy a CDK into AWS, which will be use later on to deploy OSM on top of it. Also, we will need to create an overlay.yaml file in order to include several things:
osm-vca: Charm needed by LCM (OSM component) to host the Proxy Charms. -
kubernetes-worker: 4 workers are needed. -
aws-integrator: Charm needed to have CDK working on AWS.
cat << EOF > overlay.yaml
applications:
osm-vca:
charm: cs:~charmed-osm/vca
num_units: 1
constraints: mem=4G cores=2 root-disk=40G
kubernetes-worker:
num_units: 4
aws-integrator:
charm: cs:~containers/aws-integrator
num_units: 1
relations:
- ['aws-integrator', 'kubernetes-master']
- ['aws-integrator', 'kubernetes-worker']
EOF
Deploy CDK and OSM-VCA with the following commands:
juju add-model cdk
juju deploy charmed-kubernetes --overlay overlay.yaml
juju trust aws-integrator
juju offer osm-vca:osm-vca # Offer osm-vca for a Cross-Model Relation
The command juju find-offers shows the URL of the offered interface (admin/cdk.osm-vca).
Store URL Access Interfaces
aws-osm-ha admin/cdk.osm-vca admin osm-vca:osm-vca
Boostrap CDK Cloud
Before bootstrapping the CDK Cloud, it’s important to wait until CDK is up and running. We know that when the Message of the kubernetes-master is “Kubernetes master running”. This can take 20 minutes.
watch -c juju status --color
cdk aws-osm-ha aws/us-east-1 2.6.5 unsupported 11:16:01+02:00
aws-integrator 1.16.148 active 1 aws-integrator jujucharms 10 ubuntu
containerd active 6 containerd jujucharms 2 ubuntu
easyrsa 3.0.1 active 1 easyrsa jujucharms 254 ubuntu
etcd 3.2.10 active 3 etcd jujucharms 434 ubuntu
flannel 0.10.0 active 6 flannel jujucharms 425 ubuntu
kubeapi-load-balancer 1.14.0 active 1 kubeapi-load-balancer jujucharms 649 ubuntu exposed
kubernetes-master 1.15.0 active 2 kubernetes-master jujucharms 700 ubuntu
kubernetes-worker 1.15.0 active 4 kubernetes-worker jujucharms 552 ubuntu exposed
osm-vca active 1 vca jujucharms 0 ubuntu
aws-integrator/0* active idle 0 3.88.26.246 Ready
easyrsa/0* active idle 1 34.207.79.236 Certificate Authority connected.
etcd/0 active idle 2 3.95.158.127 2379/tcp Healthy with 3 known peers
etcd/1 active idle 3 18.208.142.176 2379/tcp Healthy with 3 known peers
etcd/2* active idle 4 18.209.101.141 2379/tcp Healthy with 3 known peers
kubeapi-load-balancer/0* active idle 5 3.219.35.137 443/tcp Loadbalancer ready.
kubernetes-master/0 active idle 6 35.174.154.229 6443/tcp Kubernetes master running.
containerd/5 active idle 35.174.154.229 Container runtime available.
flannel/5 active idle 35.174.154.229 Flannel subnet 10.1.62.1/24
kubernetes-master/1* active idle 7 3.89.29.87 6443/tcp Kubernetes master running.
containerd/4 active idle 3.89.29.87 Container runtime available.
flannel/4 active idle 3.89.29.87 Flannel subnet 10.1.11.1/24
kubernetes-worker/0* active idle 8 18.215.124.61 80/tcp,443/tcp Kubernetes worker running.
containerd/0* active idle 18.215.124.61 Container runtime available.
flannel/0* active idle 18.215.124.61 Flannel subnet 10.1.81.1/24
kubernetes-worker/1 active idle 9 54.211.52.28 80/tcp,443/tcp Kubernetes worker running.
containerd/2 active idle 54.211.52.28 Container runtime available.
flannel/2 active idle 54.211.52.28 Flannel subnet 10.1.23.1/24
kubernetes-worker/2 active idle 10 3.93.171.170 80/tcp,443/tcp Kubernetes worker running.
containerd/1 active idle 3.93.171.170 Container runtime available.
flannel/1 active idle 3.93.171.170 Flannel subnet 10.1.66.1/24
kubernetes-worker/3 active idle 11 3.94.78.179 80/tcp,443/tcp Kubernetes worker running.
containerd/3 active idle 3.94.78.179 Container runtime available.
flannel/3 active idle 3.94.78.179 Flannel subnet 10.1.83.1/24
osm-vca/0* active idle 12 18.207.243.174 configured
0 started 3.88.26.246 i-060581800c9b3de9e bionic us-east-1a running
1 started 34.207.79.236 i-0e5be760554ea0b16 bionic us-east-1b running
2 started 3.95.158.127 i-0c723a5c9330a17e3 bionic us-east-1a running
3 started 18.208.142.176 i-0ccdc065640112f5d bionic us-east-1b running
4 started 18.209.101.141 i-0431891ab2dcc004b bionic us-east-1c running
5 started 3.219.35.137 i-053071bbc1f012ae1 bionic us-east-1d running
6 started 35.174.154.229 i-091a0b6e8dadcfa6c bionic us-east-1a running
7 started 3.89.29.87 i-08826546e130c1515 bionic us-east-1b running
8 started 18.215.124.61 i-0f73acd5c5eeef2e6 bionic us-east-1d running
9 started 54.211.52.28 i-09933015cbd3cd922 bionic us-east-1c running
10 started 3.93.171.170 i-031171240a1a70b5b bionic us-east-1b running
11 started 3.94.78.179 i-029902110200145cb bionic us-east-1a running
12 started 18.207.243.174 i-05592992d699d3d2f bionic us-east-1f running
Offer Application Charm Rev Connected Endpoint Interface Role
osm-vca osm-vca vca 0 0/0 osm-vca osm-vca provider
Get CDK credentials
The credentials of the Kubernetes needs to be stored in ~/.kube/config. For copying the credentials and installing the kubectl client, execute the following commands:
mkdir ~/.kube
juju scp kubernetes-master/0:config ~/.kube/config
sudo snap install kubectl --classic
Create Storage
These additional commands are needed to create storages for CDK to be working in AWS.
# Create a storage class using the `kubernetes.io/aws-ebs` provisioner
kubectl create -f - <<EOY
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: kubernetes.io/aws-ebs
parameters:
type: gp2
EOY
# Create a persistent volume claim using that storage class
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 100Mi
storageClassName: ebs-1
EOY
Bootstrap Controller
Insert the region you got before in the juju status command.
cat ~/.kube/config | juju add-k8s k8s-cloud --local --region=aws/us-east-1
juju bootstrap k8s-cloud
Deploy OSM
This section covers the deployment of OSM, and we will use a osm namespace for it.
juju add-model osm
Create storage pools
Create the needed storage pools for OSM:
juju create-storage-pool operator-storage kubernetes
juju create-storage-pool osm-pv kubernetes
juju create-storage-pool packages-pv kubernetes
Deploy
Deploy OSM simply by executing the following:
juju deploy osm-ha
Cross-model-relation: <controller_name>:<URL>
Add the cross-model relation between osm-vca and lcm.
juju add-relation lcm-k8s aws-osm-ha:admin/cdk.osm-vca
HOW TO
Access OSM UI
Take the IP of one of the kubernetes-workers (p.e. 18.215.124.61), and execute the following commands:
juju config ui-k8s juju-external-hostname=osm.18.215.124.61.xip.io
juju expose ui-k8s
juju config prometheus-k8s juju-external-hostname=prometheus.18.215.124.61.xip.io
juju expose prometheus-k8s
juju config grafana-k8s juju-external-hostname=grafana.18.215.124.61.xip.io
juju expose grafana-k8s
The ingress module uses nginx. By default, it has the option proxy-body-size to 1m. This will be a problem if a VNF package of more than 1m is uploaded. To solve it, we only have to add an annotation to the ingress.
kubectl -n osm edit ingress ui-k8s
# Add the following line in the annotations
nginx.ingress.kubernetes.io/proxy-body-size: "0"
You can access now these services:
- OSM: http://osm.18.215.124.61.xip.io
- Prometheus: http://prometheus.18.215.124.61.xip.io
- Grafana: http://grafana.18.215.124.61.xip.io
Check OSM status
$ juju status
osm k8s-cloud-us-east-1 k8s-cloud/us-east-1 2.6.5 unsupported 21:18:23+02:00
App Version Status Scale Charm Store Rev OS Address Notes
grafana-k8s active 3 grafana-k8s jujucharms 15 kubernetes 10.152.183.161
kafka-k8s active 3 kafka-k8s jujucharms 1 kubernetes 10.152.183.48
lcm-k8s active 3 lcm-k8s jujucharms 20 kubernetes 10.152.183.75
mariadb-k8s active 3 mariadb-k8s jujucharms 13 kubernetes 10.152.183.31
mon-k8s active 3 mon-k8s jujucharms 14 kubernetes 10.152.183.171
mongodb-k8s active 3 mongodb-k8s jujucharms 14 kubernetes 10.152.183.109
nbi-k8s active 3 nbi-k8s jujucharms 19 kubernetes 10.152.183.252
pol-k8s active 3 pol-k8s jujucharms 14 kubernetes 10.152.183.194
prometheus-k8s active 3 prometheus-k8s jujucharms 12 kubernetes 10.152.183.55
ro-k8s active 3 ro-k8s jujucharms 14 kubernetes 10.152.183.168
ui-k8s active 3 ui-k8s jujucharms 23 kubernetes 10.152.183.230 exposed
zookeeper-k8s active 3 zookeeper-k8s jujucharms 16 kubernetes 10.152.183.199
grafana-k8s/0* active idle 10.1.38.43 3000/TCP configured
grafana-k8s/1 active idle 10.1.31.47 3000/TCP configured
grafana-k8s/2 active idle 10.1.42.79 3000/TCP configured
kafka-k8s/0* active idle 10.1.38.38 9092/TCP configured
kafka-k8s/1 active idle 10.1.42.73 9092/TCP configured
kafka-k8s/2 active idle 10.1.31.41 9092/TCP configured
lcm-k8s/0* active idle 10.1.38.41 80/TCP configured
lcm-k8s/1 active idle 10.1.42.76 80/TCP configured
lcm-k8s/2 active idle 10.1.31.44 80/TCP configured
mariadb-k8s/0* active idle 10.1.38.33 3306/TCP,4444/TCP,4567/TCP,4568/TCP configured
mariadb-k8s/1 active idle 10.1.42.80 3306/TCP,4444/TCP,4567/TCP,4568/TCP configured
mariadb-k8s/2 active idle 10.1.31.48 3306/TCP,4444/TCP,4567/TCP,4568/TCP configured
mon-k8s/0* active idle 10.1.38.42 8000/TCP configured
mon-k8s/1 active idle 10.1.42.77 8000/TCP configured
mon-k8s/2 active idle 10.1.31.45 8000/TCP configured
mongodb-k8s/0 active idle 10.1.38.35 27017/TCP configured
mongodb-k8s/1* active idle 10.1.42.70 27017/TCP configured
mongodb-k8s/2 active idle 10.1.31.39 27017/TCP configured
nbi-k8s/0* active idle 10.1.38.40 9999/TCP configured
nbi-k8s/1 active idle 10.1.42.75 9999/TCP configured
nbi-k8s/2 active idle 10.1.31.43 9999/TCP configured
pol-k8s/0* active idle 10.1.38.39 80/TCP configured
pol-k8s/1 active idle 10.1.42.74 80/TCP configured
pol-k8s/2 active idle 10.1.31.42 80/TCP configured
prometheus-k8s/0* active idle 10.1.38.44 9090/TCP configured
prometheus-k8s/1 active idle 10.1.42.78 9090/TCP configured
prometheus-k8s/2 active idle 10.1.31.46 9090/TCP configured
ro-k8s/0* active idle 10.1.38.37 9090/TCP configured
ro-k8s/1 active idle 10.1.42.72 9090/TCP configured
ro-k8s/2 active idle 10.1.31.40 9090/TCP configured
ui-k8s/0* active idle 10.1.31.37 80/TCP configured
ui-k8s/1 active idle 10.1.38.34 80/TCP configured
ui-k8s/2 active idle 10.1.42.69 80/TCP configured
zookeeper-k8s/0* active idle 10.1.38.36 2181/TCP,2888/TCP,3888/TCP configured
zookeeper-k8s/1 active idle 10.1.42.71 2181/TCP,2888/TCP,3888/TCP configured
zookeeper-k8s/2 active idle 10.1.31.38 2181/TCP,2888/TCP,3888/TCP configured
Scale applications
Some applications such as MariaDB and RO (OSM) need to be scaled after the deployment is finished. We are working on improving that, but in the meantime, you should execute the following commands:
- Scale MariaDB cluster
juju scale-application mariadb-k8s 3
- Scale RO
juju scale-application ro-k8s 3
How to clean up
The easiest way to clean up everything is executing the following commands:
juju kill-controller aws-osm-ha -t 0 -y
juju unregister k8s-cloud-us-east-1
How to use OSM
This topic
