Deploy openstack "default Failed deployment: Loading ephemeral"
Hi Dear I’m trying to deploy Openstack base via Juju (2.7.6) on my virtual lab (Maas 2.8.2 and Ubuntu 20.04) but after I run the command
$: juju deploy cs:bundle/openstack-base-70
the machine started the deploy of OS (20.04)
but after a couple of minutes obtained this issue Screenshot%20from%202020-09-05%2015-08-57
on their log I saw these line:
curtin: Installation started. (20.1-2-g42a9667f-0ubuntu1~18.04.1)
is it normal seeing the 18.04??? while at the end of file:
Generating grub debconf_selections for devices=[‘/dev/vda’] uefi=False finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/install-grub: FAIL: installing grub to target devices finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-bootloader: FAIL: configuring target system bootloader finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: FAIL: curtin command curthooks Traceback (most recent call last): File “/curtin/curtin/commands/main.py”, line 202, in main ret = args.func(args) File “/curtin/curtin/commands/curthooks.py”, line 1770, in curthooks builtin_curthooks(cfg, target, state) File “/curtin/curtin/commands/curthooks.py”, line 1736, in builtin_curthooks setup_grub(cfg, target, osfamily=osfamily) File “/curtin/curtin/commands/curthooks.py”, line 689, in setup_grub configure_grub_debconf(instdevs, target, uefi_bootable) File “/curtin/curtin/commands/curthooks.py”, line 509, in configure_grub_debconf link = block.disk_to_byid_path(dev) File “/curtin/curtin/block/init.py”, line 869, in disk_to_byid_path mapping = get_dev_disk_byid() File “/curtin/curtin/block/init.py”, line 861, in get_dev_disk_byid return _get_dev_disk_by_prefix(‘/dev/disk/by-id’) File “/curtin/curtin/block/init.py”, line 846, in _get_dev_disk_by_prefix for path in os.listdir(prefix)] FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/disk/by-id’ [Errno 2] No such file or directory: ‘/dev/disk/by-id’
and on Juju status the situation is that
I’ve also tried to deploy another charm and the result is ok
Screenshot%20from%202020-09-05%2015-19-17
someone can help me? thanks a lot
@sparkiegeek can we get a MAAS person to weigh in here to help diagnose where to look next?
Are you using vmware or suchlike? If you don’t have a proper disk id the default storage layout does not work now. Try with LVM.
Can you deploy the servers with maas only to verify that your nodes can be deployed at all?
If not, try to commission them again and then try again until you know your maas works before you get juju in to the picture.
I’ll try to use LVM instead of default storage. I’ll inform you soon
Making the deploy via MAAS I haven’t any issue, the VM called ubuntu.maas has been made in that way.
Probably due to LP #1876258. This is a curtin issue that occurs when a KVM-based disk does not have a serial number. A fix has been committed so I guess it’s a matter of when a backport can be made to Ubuntu 20.04 LTS. A workaround is to manually add serial numbers.
@pmatulis @routergod maybe I’ve resolved that, but I’ve to try the same procedure made for the bootstrap also for the VM dedicated to Openstack, soon my feedback
after the changes on all the VMs and run the deploy of its bundle base, the situation is completed different
I’m waiting that the procedure finish. At this point I don’t know if that issue is a bug or the VMs have to be set via LVM storage.
sorry, the result after the deploy
but on its status there are that error:
keystone/0*                  blocked   idle   0/lxd/2  10.0.0.20       5000/tcp           Incomplete relations: database, Allowed_units list provided but this unit not present
  keystone-mysql-router/0*   waiting   idle            10.0.0.20                          'db-router' incomplete, MySQL Router not yet bootstrapped
mysql-innodb-cluster/0       error     idle   0/lxd/3  10.0.0.19                          hook failed: "install"
I have to wait???see too many waiting
@riccardo-magrini it appears you have resolved or worked-around the issue you were having with your virtual disk ids and now you have a separate problem with your Mysql8 cluster. The nature of the error is not clear without some logs.
Please try to identify the error from the debug log
juju debug-log --include mysql-innodb-cluster
It might take a while for the charm to wake up and do something if stuck in “error, idle”, you might want to give it a kick like this;
juju resolve mysql-innodb-cluster/0
I hope you find some clues!
after 3hrs the situation of the deploy is that:
$:juju status
Model      Controller             Cloud/Region        Version  SLA          Timestamp
openstack  maas-cloud-controller  maas-cloud/default  2.8.1    unsupported  17:36:34Z
App                     Version  Status   Scale  Charm                   Store       Rev  OS      Notes
ceph-mon                15.2.3   blocked      3  ceph-mon                jujucharms   49  ubuntu
ceph-osd                15.2.3   active       3  ceph-osd                jujucharms  304  ubuntu
ceph-radosgw            15.2.3   waiting      1  ceph-radosgw            jujucharms  290  ubuntu
cinder                  16.1.0   active       1  cinder                  jujucharms  304  ubuntu
cinder-ceph             16.1.0   active       1  cinder-ceph             jujucharms  257  ubuntu
cinder-mysql-router     8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
dashboard-mysql-router  8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
glance                  20.0.0   active       1  glance                  jujucharms  298  ubuntu
glance-mysql-router     8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
keystone                17.0.0   active       1  keystone                jujucharms  317  ubuntu
keystone-mysql-router   8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
mysql-innodb-cluster    8.0.21   active       3  mysql-innodb-cluster    jujucharms    1  ubuntu
neutron-api             16.0.0   active       1  neutron-api             jujucharms  287  ubuntu
neutron-api-plugin-ovn  16.0.0   waiting      1  neutron-api-plugin-ovn  jujucharms    1  ubuntu
neutron-mysql-router    8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
nova-cloud-controller   21.0.0   active       1  nova-cloud-controller   jujucharms  346  ubuntu
nova-compute            21.0.0   active       3  nova-compute            jujucharms  319  ubuntu
nova-mysql-router       8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
ntp                     3.5      active       3  ntp                     jujucharms   41  ubuntu
openstack-dashboard     18.3.2   active       1  openstack-dashboard     jujucharms  305  ubuntu
ovn-central             20.03.0  waiting      3  ovn-central             jujucharms    1  ubuntu
ovn-chassis             20.03.0  waiting      3  ovn-chassis             jujucharms    3  ubuntu
placement               3.0.0    active       1  placement               jujucharms   12  ubuntu
placement-mysql-router  8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
rabbitmq-server         3.8.2    active       1  rabbitmq-server         jujucharms  104  ubuntu
vault                   1.1.1    blocked      1  vault                   jujucharms   40  ubuntu
vault-mysql-router      8.0.21   active       1  mysql-router            jujucharms    3  ubuntu
Unit                         Workload  Agent  Machine  Public address  Ports              Message
ceph-mon/0*                  blocked   idle   0/lxd/0  10.0.0.86                          Unit not clustered (no quorum)
ceph-mon/1                   active    idle   1/lxd/0  10.0.0.96                          Unit is ready and clustered
ceph-mon/2                   active    idle   2/lxd/0  10.0.0.89                          Unit is ready and clustered
ceph-osd/0                   active    idle   0        10.0.0.22                          Unit is ready (1 OSD)
ceph-osd/1                   active    idle   1        10.0.0.23                          Unit is ready (1 OSD)
ceph-osd/2*                  active    idle   2        10.0.0.21                          Unit is ready (1 OSD)
ceph-radosgw/0*              waiting   idle   0/lxd/1  10.0.0.88       80/tcp             Incomplete relations: mon
cinder/0*                    active    idle   1/lxd/1  10.0.0.97       8776/tcp           Unit is ready
  cinder-ceph/0*             active    idle            10.0.0.97                          Unit is ready
  cinder-mysql-router/0*     active    idle            10.0.0.97                          Unit is ready
glance/0*                    active    idle   2/lxd/1  10.0.0.93       9292/tcp           Unit is ready
  glance-mysql-router/0*     active    idle            10.0.0.93                          Unit is ready
keystone/0*                  active    idle   0/lxd/2  10.0.0.84       5000/tcp           Unit is ready
  keystone-mysql-router/0*   active    idle            10.0.0.84                          Unit is ready
mysql-innodb-cluster/0       active    idle   0/lxd/3  10.0.0.98                          Unit is ready: Mode: R/O
mysql-innodb-cluster/1*      active    idle   1/lxd/2  10.0.0.100                         Unit is ready: Mode: R/O
mysql-innodb-cluster/2       active    idle   2/lxd/2  10.0.0.99                          Unit is ready: Mode: R/W
neutron-api/0*               active    idle   1/lxd/3  10.0.0.92       9696/tcp           Unit is ready
  neutron-api-plugin-ovn/0*  waiting   idle            10.0.0.92                          'certificates' awaiting server certificate data, 'ovsdb-cms' incomplete
  neutron-mysql-router/0*    active    idle            10.0.0.92                          Unit is ready
nova-cloud-controller/0*     active    idle   0/lxd/4  10.0.0.102      8774/tcp,8775/tcp  Unit is ready
  nova-mysql-router/0*       active    idle            10.0.0.102                         Unit is ready
nova-compute/0               active    idle   0        10.0.0.22                          Unit is ready
  ntp/0*                     active    idle            10.0.0.22       123/udp            chrony: Ready
  ovn-chassis/0*             waiting   idle            10.0.0.22                          'certificates' awaiting server certificate data, 'ovsdb' incomplete
nova-compute/1               active    idle   1        10.0.0.23                          Unit is ready
  ntp/2                      active    idle            10.0.0.23       123/udp            chrony: Ready
  ovn-chassis/2              waiting   idle            10.0.0.23                          'certificates' awaiting server certificate data, 'ovsdb' incomplete
nova-compute/2*              active    idle   2        10.0.0.21                          Unit is ready
  ntp/1                      active    idle            10.0.0.21       123/udp            chrony: Ready
  ovn-chassis/1              waiting   idle            10.0.0.21                          'certificates' awaiting server certificate data, 'ovsdb' incomplete
openstack-dashboard/0*       active    idle   1/lxd/4  10.0.0.91       80/tcp,443/tcp     Unit is ready
  dashboard-mysql-router/0*  active    idle            10.0.0.91                          Unit is ready
ovn-central/0                waiting   idle   0/lxd/5  10.0.0.94       6641/tcp,6642/tcp  'ovsdb-peer' incomplete, 'certificates' awaiting server certificate data
ovn-central/1*               waiting   idle   1/lxd/5  10.0.0.90       6641/tcp,6642/tcp  'ovsdb-peer' incomplete, 'certificates' awaiting server certificate data
ovn-central/2                waiting   idle   2/lxd/3  10.0.0.87       6641/tcp,6642/tcp  'ovsdb-peer' incomplete, 'certificates' awaiting server certificate data
placement/0*                 active    idle   2/lxd/4  10.0.0.85       8778/tcp           Unit is ready
  placement-mysql-router/0*  active    idle            10.0.0.85                          Unit is ready
rabbitmq-server/0*           active    idle   2/lxd/5  10.0.0.101      5672/tcp           Unit is ready
vault/0*                     blocked   idle   0/lxd/6  10.0.0.95       8200/tcp           Vault needs to be initialized
  vault-mysql-router/0*      active    idle            10.0.0.95                          Unit is ready
Machine  State    DNS         Inst id              Series  AZ       Message
0        started  10.0.0.22   openstack02          focal   default  Deployed
0/lxd/0  started  10.0.0.86   juju-ab0a09-0-lxd-0  focal   default  Container started
0/lxd/1  started  10.0.0.88   juju-ab0a09-0-lxd-1  focal   default  Container started
0/lxd/2  started  10.0.0.84   juju-ab0a09-0-lxd-2  focal   default  Container started
0/lxd/3  started  10.0.0.98   juju-ab0a09-0-lxd-3  focal   default  Container started
0/lxd/4  started  10.0.0.102  juju-ab0a09-0-lxd-4  focal   default  Container started
0/lxd/5  started  10.0.0.94   juju-ab0a09-0-lxd-5  focal   default  Container started
0/lxd/6  started  10.0.0.95   juju-ab0a09-0-lxd-6  focal   default  Container started
1        started  10.0.0.23   openstack03          focal   default  Deployed
1/lxd/0  started  10.0.0.96   juju-ab0a09-1-lxd-0  focal   default  Container started
1/lxd/1  started  10.0.0.97   juju-ab0a09-1-lxd-1  focal   default  Container started
1/lxd/2  started  10.0.0.100  juju-ab0a09-1-lxd-2  focal   default  Container started
1/lxd/3  started  10.0.0.92   juju-ab0a09-1-lxd-3  focal   default  Container started
1/lxd/4  started  10.0.0.91   juju-ab0a09-1-lxd-4  focal   default  Container started
1/lxd/5  started  10.0.0.90   juju-ab0a09-1-lxd-5  focal   default  Container started
2        started  10.0.0.21   openstack01          focal   default  Deployed
2/lxd/0  started  10.0.0.89   juju-ab0a09-2-lxd-0  focal   default  Container started
2/lxd/1  started  10.0.0.93   juju-ab0a09-2-lxd-1  focal   default  Container started
2/lxd/2  started  10.0.0.99   juju-ab0a09-2-lxd-2  focal   default  Container started
2/lxd/3  started  10.0.0.87   juju-ab0a09-2-lxd-3  focal   default  Container started
2/lxd/4  started  10.0.0.85   juju-ab0a09-2-lxd-4  focal   default  Container started
2/lxd/5  started  10.0.0.101  juju-ab0a09-2-lxd-5  focal   default  Container started
there are also some “waiting” and a stopped…
anyway. opening Horizon the gui is ok
Looks ok, you just need to initialize vault to complete the certificates relations, see https://docs.openstack.org/project-deploy-guide/charm-deployment-guide/latest/app-vault.html
Hi @riccardo-magrini I am stuck in below situation
openstack  my-controller  localhost/localhost  3.6.11   unsupported  14:44:25+05:30
App                       Version  Status   Scale  Charm                  Channel        Rev  Exposed  Message
cinder                    23.0.0   waiting      1  cinder                 2024.1/stable  690  no       Incomplete relations: identity, messaging, database
cinder-lvm                         unknown      0  cinder-lvm             2024.1/stable  131  no
cinder-mysql-router                unknown      0  mysql-router           8.0/stable     257  no
glance                             waiting    0/1  glance                 yoga/stable    620  no       waiting for machine
glance-mysql-router                unknown      0  mysql-router           8.0/stable     257  no
keystone                           waiting    0/1  keystone               2024.1/stable  753  no       waiting for machine
keystone-mysql-router              unknown      0  mysql-router           8.0/stable     257  no
mysql-innodb-cluster               waiting    0/1  mysql-innodb-cluster   8.0/stable     159  no       waiting for machine
neutron-api                        waiting    0/1  neutron-api            2024.1/stable  624  no       waiting for machine
neutron-api-mysql-router           unknown      0  mysql-router           8.0/stable     257  no
neutron-openvswitch       24.1.0   waiting      1  neutron-openvswitch    2024.1/stable  578  no       Incomplete relations: messaging
nova-cc-mysql-router               unknown      0  mysql-router           8.0/stable     257  no
nova-cloud-controller              waiting    0/1  nova-cloud-controller  2024.1/stable  791  no       waiting for machine
nova-compute              29.2.0   waiting      1  nova-compute           2024.1/stable  802  no       Incomplete relations: messaging, image
openstack-dashboard                waiting    0/1  openstack-dashboard    2024.1/stable  704  no       waiting for machine
rabbitmq-server                    waiting    0/1  rabbitmq-server        3.9/stable     246  no       waiting for machine
can you please help me
