Hi, We have renamed namecheap-lego-operator to namecheap-acme-operator. Should we delete namecheap-lego-operator ?
Thank you, Yazan
Thank you, Yazan
We typically prefer not to delete charms. You can close all channels or I can set the charm as unlisted.
Let me know if that works; if not, I can delete it, but be aware you may break deployments or bundles using the old name.
I have closed the channels, do we need to set it to unlisted too?
Thank you, Yazan
