Data Integrator Documentation
The Data Integrator charm enables applications or users outside Juju to connect and authenticate with a charmed database application. It automatically provides credentials and endpoints that are needed to use the desired product.
This documentation is currently under construction. For general information about its config options and basic usage, check the README on GitHub.
For specific instructions about how to connect an application outside of Juju to a database using Data Integrator, check the documentation for the relevant database charm in the table below:
| Database | ||
| Charmed PostgreSQL | VM & K8s | |
| Charmed MySQL | VM & K8s | |
| Charmed MongoDB | VM & K8s | |
| Charmed OpenSearch | VM | |
| Charmed Spark | K8s | |
| Charmed Kafka | VM | K8s |
Project and community
Data Integrator is an open-source project that welcomes community contributions, suggestions, fixes and constructive feedback.
Navigation
| Level | Path | Navlink |
| 1 | reference | Reference |
| 2 | r-releases | Release notes |
Redirects
Mapping table
| Path | Location |
