Following the documentation I encounter an unexpected error during database migration;
$ juju run-action --wait neutron-api-plugin-ovn/0 migrate-ovn-db i-really-mean-it=true
Stdout: "migrate-ovn-db: OUTPUT FROM SYNC ON STDOUT:\n2020-11-25 11:06:17.760
413761 INFO neutron.cmd.ovn.neutron_ovn_db_sync_util [-] Started Neutron OVN
db sync\e[00m\n
11:06:57.026 413761 WARNING neutron.db.ovn_revision_numbers_db [req-91be95af-c8c7-41cc-a372-5cd7a0241373
- - - - -] No revision row found for e50ff198-0fb5-4fd4-9b6c-d2f4b0a3f575 (type:
networks) when bumping the revision number. Creating one.\e[00m\n2020-11-25
11:06:57.227 413761 INFO neutron.db.ovn_revision_numbers_db [req-91be95af-c8c7-41cc-a372-5cd7a0241373
- - - - -] Successfully bumped revision number for resource e50ff198-0fb5-4fd4-9b6c-d2f4b0a3f575
(type: networks) to 10\e[00m\n2020-11-25 11:06:57.565 413761 CRITICAL neutron_ovn_db_sync_util
[req-91be95af-c8c7-41cc-a372-5cd7a0241373 - - - - -] Unhandled error: neutron_lib.exceptions.IpAddressGenerationFailure:
No more IP addresses available on network e50ff198-0fb5-4fd4-9b6c-d2f4b0a3f575.\n2020-11-25
11:06:57.565 413761 ERROR neutron_ovn_db_sync_util Traceback (most recent call
last):\n
I figure something strange with the configuration of this network e50ff198-0fb5-4fd4-9b6c-d2f4b0a3f575, but it results in a partial migration so need to unwind something to fix it.
The neutron-api is paused at this point and in the config, manage-neutron-plugin-legacy-mode=false. Can I safely resume the neutron-api to diagnose the network?
Many thanks in advance for any clue!
