Our roadmap includes versioning on Charmhub for Charmed MongoDB (VM) and we need the channels:
5.0/edge
5.0/candidate
5.0/stable
to track the different releases of Charmed MongoDB for version 5.0
Thanks for the help!
5.0/edge
5.0/candidate
5.0/stable
Hi,
I think I only need to create the 5.0 track. I can do so gladly; can you confirm that charmed-mongodb is the name of the charm?
Hi @roadmr . Thank you! On charmhub the name is listed as Charmed MongoDB but if you look its deployed as mongodb. I’m not sure which of these is the one I should be referncing.
I’ve created the 5.0 track.
Thanks a ton @roadmr
@roadmr there was a recent strategy change and it has now been requested that we use track 5 instead of 5.0 . My apologies for the extra work created here
Not a problem ! 5 track is now created.
Thanks a much for your understanding @roadmr and for doing that so quickly!
