cos-proxy services are running
Confirm the nrpe-exporter is functioning:
juju ssh cos-proxy-monitors/0 systemctl status nrpe-exporter
Confirm vector behaves as expected:
systemctl status vector
journalctl -u vector
vector top
In vector top you should see reasonable incoming and outgoing traffic.
Try to run NRPE checks manually
Confirm the checks run and produce expected output, for example:
$ /usr/local/lib/nagios/plugins/check_systemd.py aodh-listener
OK: aodh-listener.service is running
cos-proxy has COS relations
Inspect juju status to make sure that cos-proxy has cross-model relations to COS charms:
cos-proxy:downstream-prometheus-scrape prom:metrics-endpoint prometheus_scrape regular
Similar for loki, grafana.
If cos-proxy is related to scrape-config, then make sure scrape-config is related to prometheus.
Rule files and scrape configs reached prometheus
Make sure the the expected rule files appear are forwarded to prometheus over relation data:
juju show-unit prom/0 --format=json \
| jq '."prom/0"."relation-info" | .[] | select(.endpoint == "metrics-endpoint")."application-data"'
and that the same rules were written to disk:
juju ssh --container prometheus prom/0 ls /etc/prometheus/rules
and that the same rules were picked up by prometheus:
curl $(juju status --format=json | jq -r '.applications.prom.address'):9090/api/v1/rules | jq
Are nrpe metrics being scraped by prometheus?
- In the cos-proxy VM, run
vector topand look at the “Bytes” column for prometheus exporter. If it isn’t growing then metrics are not being scraped by prometheus. - In prometheus, confirm that there are targets (scrape jobs) for the nrpe metrics:
- In prometheus web UI, under Status → Targets; or
- curl
:9090/api/v1/targets
- Can the scrape targets be reached from within prometheus? (A manual curl would do.)
- Check if prom has any
command_*metrics.
