Basic deployment
Deploy Canonical Observability Stack (Lite) on a model backed by Kubernetes, then deploy the cos-proxy operator in a reactive/machine model from which you would like to collect observability data.
The cos-proxy operator is designed to work with cross-model relations, so the first step is to establish those:
juju offer cos.prometheus:metrics-endpoint
juju offer cos.grafana:grafana-dashboard
juju consume cos.prometheus
juju consume cos.grafana
Next, deploy the cos-proxy operator in a reactive model:
juju deploy -m reactive cos-proxy --channel=beta
For any charm which may export:
- Grafana dashboards
- Prometheus metrics endpoints
- Prometheus alert rules
- NRPE jobs
You may relate them to cos-proxy. “Topology” for model-driven observability will be automatically injected into Prometheus labels and Alert rule expressions.
NRPE jobs are checked via nrpe_exporter, which provides a Prometheus-compatible HTTP endpoint which knows how to speak to NRPE.
For example:
❯ juju status -m dash --color --relations
reactive overlord lxdremote/default 2.9.22 unsupported 16:43:14Z
SAAS Status Store URL
grafana active overlord admin/cos.grafana
prometheus active overlord admin/cos.prometheus
App Version Status Scale Charm Store Channel Rev OS Message
cos-proxy active 1 cos-proxy local 14 ubuntu
memcached active 1 memcached charmstore stable 34 ubuntu Unit is ready
nagios active 1 nagios charmstore stable 46 ubuntu ready
nrpe active 2 nrpe charmstore stable 75 ubuntu Ready (source version/commit cs-nrpe-...)
telegraf active 1 telegraf charmstore stable 44 ubuntu Monitoring ubuntu/0 (source version/commit 26e531a)
ubuntu 20.04 active 1 ubuntu charmstore stable 18 ubuntu
cos-proxy/14* active idle 17 10.159.132.117
memcached/0* active idle 2 10.159.132.52 11211/tcp Unit is ready
nrpe/1 active idle 10.159.132.52 icmp,5666/tcp Ready (source version/commit cs-nrpe-...)
nagios/0* active idle 1 10.159.132.207 80/tcp ready
ubuntu/0* active idle 0 10.159.132.173
nrpe/0* active idle 10.159.132.173 icmp,5666/tcp Ready (source version/commit cs-nrpe-...)
telegraf/6* active idle 10.159.132.173 9103/tcp Monitoring ubuntu/0 (source version/commit 26e531a)
0 started 10.159.132.173 juju-dda879-0 focal Running
1 started 10.159.132.207 juju-dda879-1 bionic Running
2 started 10.159.132.52 juju-dda879-2 focal Running
17 started 10.159.132.117 juju-dda879-17 focal Running
cos-proxy:downstream-prometheus-scrape prometheus:metrics-endpoint prometheus_scrape regular
memcached:cluster memcached:cluster memcached-replication peer
memcached:juju-info nrpe:general-info juju-info subordinate
memcached:local-monitors nrpe:local-monitors local-monitors subordinate
memcached:monitors cos-proxy:monitors monitors regular
memcached:nrpe-external-master nrpe:nrpe-external-master nrpe-external-master subordinate
nrpe:monitors cos-proxy:monitors monitors regular
nrpe:monitors nagios:monitors monitors regular
ubuntu:juju-info nrpe:general-info juju-info subordinate
ubuntu:juju-info telegraf:juju-info juju-info subordinate
Note: “system”-level NRPE jobs, such as check_conntrack are exposed on the monitors interface, while “charm”-level jobs specific to the workload are exposed on the local-monitors interface, and may not be provisioned until a nrpe-external-master relation is established.
To accurately pull all NRPE jobs from a charm, all of these relations should be established. This is an identical user experience to the nrpe charm, but it’s documented here for completeness.
