By the end of this tutorial you will be able to run pyfiglet via docker:
$ docker run --rm -it pyfiglet:0.7.6 exec pyfiglet hello
_ _ _
| |__ ___| | | ___
| '_ \ / _ \ | |/ _ \
| | | | __/ | | (_) |
|_| |_|\___|_|_|\___/
rockcraft, docker, skopeo and lxd are installed (there is a multipass docker blueprint to help with that).
rockcraft.yaml
With rockcraft, we build images from a rockcraft.yaml file rather than a Dockerfile.
To create a new rock project,
mkdir pyfiglet-rock && cd pyfiglet-rock
rockcraft init
Next, update the file to look like this:
base: ubuntu:22.04
version: '0.7.6' # Note: should match `pyfiglet` below
summary: A rock for pyfiglet
description: A rock for pyfiglet
license: Apache-2.0
platforms:
amd64:
parts:
pyfiglet:
plugin: python
source: .
python-packages:
- pyfiglet==0.7.6 # Note: should match `version` above
stage-packages:
- python3-venv
Pack and run
Now, build the rock:
rockcraft clean && rockcraft pack -v
Next, import the rock into docker:
skopeo --insecure-policy copy oci-archive:pyfiglet_0.7.6_amd64.rock docker-daemon:pyfiglet:0.7.6
The image is now ready to be run. The default entrypoint is pebble, and we use pebble exec to run one-shot commands:
$ docker run --rm -it pyfiglet:0.7.6 exec pyfiglet it works!
_ _ _ _
(_) |_ __ _____ _ __| | _____| |
| | __| \ \ /\ / / _ \| '__| |/ / __| |
| | |_ \ V V / (_) | | | <\__ \_|
|_|\__| \_/\_/ \___/|_| |_|\_\___(_)
To be able to poke around the container, you could add bash to stage-packages:
stage-packages:
+ - bash
After repeating rockcraft pack and skopeo copy you should be able to override the entrypoint:
$ docker run --rm -it --entrypoint bash pyfiglet:0.7.6
root@14d1812a2681:/# pyfiglet hi
_ _
| |__ (_)
| '_ \| |
|_| |_|_|
