When testing a Kubernetes charm, you can mock container interactions. When using the null state (State()), there will be no containers. So if the charm were to self.unit.containers, it would get back an empty dict.
To give the charm access to some containers, you need to pass them to the input state, like so:
State(containers=[...])
Example usage: container connectivity
from scenario.state import Container, State
state = State(containers=[
Container(name="foo", can_connect=True),
Container(name="bar", can_connect=False)
In this case, self.unit.get_container('foo').can_connect() would return True, while for ‘bar’ it would give False.
Filesystem mocks
Typically, a container will have some files that the charm will want to read or write. This is how you configure a container to give it access to filesystem mounts:
from pathlib import Path
from scenario.state import Container, State, Mount
local_file = Path('/path/to/local/real/file.txt')
can_connect=True,
mounts={'local': Mount('/local/share/config.yaml', local_file)})
Typically you’d use a temporary directory for that.
In this case, if the charm were to:
def _on_start(self, _):
foo = self.unit.get_container('foo')
content = foo.pull('/local/share/config.yaml').read()
then content would be the contents of our locally-supplied file.txt. You can use tempdir for nicely wrapping
strings and passing them to the charm via the container.
container.push works similarly, so you can write a test like:
import tempfile
from ops.charm import CharmBase
from scenario import State, Container, Mount, Context
class MyCharm(CharmBase):
def __init__(self, *args):
super().__init__(*args)
self.framework.observe(self.on.foo_pebble_ready, self._on_pebble_ready)
def _on_pebble_ready(self, _):
foo.push('/local/share/config.yaml', "TEST", make_dirs=True)
def test_pebble_push():
with tempfile.NamedTemporaryFile() as local_file:
container = Container(name='foo',
can_connect=True,
mounts={'local': Mount('/local/share/config.yaml', local_file.name)})
state_in = State(
containers=[container]
Context(
MyCharm,
meta={"name": "foo", "containers": {"foo": {}}}).run(
"start",
state_in,
assert local_file.read().decode() == "TEST"
pebble exec mocks
Mocking pebble exec means that you need to specify, for each possible command the charm might run on the container, what the result of that would be: its return code and what will be written to stdout/stderr.
from scenario import State, Container, ExecOutput, Context
LS_LL = """
.rw-rw-r-- 228 ubuntu ubuntu 18 jan 12:05 -- foo.yaml
.rw-rw-r-- 497 ubuntu ubuntu 18 jan 12:05 -- bar.yaml
drwxrwxr-x - ubuntu ubuntu 18 jan 12:06 -- baz
proc = foo.exec(['ls', '-ll'])
stdout, _ = proc.wait_output()
assert stdout == LS_LL
def test_pebble_exec():
name='foo',
exec_mock={
('ls', '-ll'): # this is the command we're mocking
ExecOutput(return_code=0, # this data structure contains all we need to mock the call.
stdout=LS_LL)
state_in = State(
state_out = Context(
MyCharm,
meta={"name": "foo", "containers": {"foo": {}}},
).run(
container.pebble_ready_event,
state_in,
