Hi,
I’m scratching my head trying to figure out how to solve my problem.
Let me explain:
I’m trying to build a simple bundle file to deploy a simple ceph cluster.
Until now, I used to declare every machines in my cluster so basically something like this :
machines:
'0':
constraints: tags=ceph zones=Z1
'1':
constraints: tags=ceph zones=Z2
'2':
applications:
ceph-mon:
charm: cs:ceph-mon
num_units: 3
to:
- lxd:0
- lxd:1
- lxd:2
ceph-osd:
charm: cs:ceph-osd
num_units: 3
to:
- 0
- 1
- 2
Now, I would like something a bit smarter by doing this kind of thing removing the “machines” part :
applications:
ceph-mon:
charm: cs:ceph-mon
constraints: tags=ceph zones=Z1,Z2
num_units: 3
to: [ lxd ] <=== this is where my problem is
ceph-osd:
charm: cs:ceph-osd
num_units: 3
How do you tell, in a bundle, that you want your application units (here, ceph-mon) to be deployed in LXD containers on dynamically assigned machines based on constraints ?
Thanks for your help.
