Configure frontend TLS
This guide provides instructions for configuring frontend Transport Layer Security (TLS) termination in Charmed Temporal.
In the context of Temporal, frontend TLS refers to the use of TLS to secure network communication between Temporal clients (SDKs, CLI, or Web UI) and the Temporal Frontend Service. The Temporal Frontend Service acts as the API gateway for client requests to the Temporal Server.
See TLS configuration reference for more details.
There are two ways to handle TLS in your deployment:
Frontend TLS – TLS termination is managed directly by the Temporal frontend.
Ingress TLS Termination – TLS is terminated at the ingress level (e.g., with NGINX).
If you need TLS termination at the ingress, see Configure Ingress with Nginx Ingress Integrator.
Important: While it’s technically possible to enable end-to-end encryption by letting Temporal handle TLS termination and having the ingress forward unencrypted traffic, this setup is not supported yet. You’ll need to choose one approach: either handle TLS at the frontend or at the ingress, but not both.
Requirements
- A Charmed Temporal deployment.
- The
temporal-k8scharm to be configured with TLS must includefrontendin itsserviceconfiguration. You can check it as follows:
juju config temporal-k8s services
frontend
Enable frontend TLS
- Integrate with a TLS certificate provider:
juju integrate temporal-k8s <tls-certificate-provider-charm>
- If the certificate needs a specific Common Name (CN) and SANS (Subject Alternative NAmes) DNS, you can configure them as follows:
juju config temporal-k8s frontend-cert-common-name=<common_name>
juju config temporal-k8s frontend-cert-sans-dns=<sans_dns_comma_separated_list>
By default, the certificate includes the unit hostname and the in-cluster service name (temporal-k8s.<model>.svc.cluster.local), which in-model clients such as the Temporal UI dial and verify against. Setting frontend-cert-sans-dns replaces these defaults. If in-model clients need to verify the certificate, include temporal-k8s.<model>.svc.cluster.local in the list.
Some certificate providers, such as public CAs, refuse internal names like *.svc.cluster.local and reject the whole request. With those providers, set frontend-cert-sans-dns to public names only. In-model clients then can’t verify the frontend certificate by hostname.
- All requests from Temporal clients to the frontend must now trust the Certificate Authority (CA) that signed the Temporal frontend certificate. You can retrieve the CA certificate from the TLS certificate provider charms by running:
juju run <tls-cert-provider-charm> get-ca-certificate
