Deploying charms from the latest/stable channel should guarantee
compatibility between charm revision and resource.
However, if you are deploying earlier revisions of the charm, use the table below as a reference for compatibility:
| Revision | Resource revision | Resource version |
| 34 | 18 | 3.1.3 |
| 33 | 18 | 3.1.3 |
| 32 | 15 | 3.1.3 |
| 31 | 14 | 2.1.0 |
You can specify both charm and resource revision in the deployment as follows:
juju deploy superset-k8s --channel=stable --revision=31 --resource superset-image=14
