Join in and watch some logs!
Logging with promtail and LOKI, grafana
Fredag, 18 november · 10:00–11:00 (Stockholm time)
Videolink: https://meet.google.com/vbe-axbg-vht
In this workshop, you’ll see some early work on the loki-promtail-grafana vm-charms.
This is how it works:
- Promtail looks at /var/log/*.log and …
- … sends it into, LOKI, that …
- … Grafana uses to visualize the generated logs.
You will be able to try it all out as it is and hopefully help out developing the charms which are currently very much early/experiental work.
- loki https://github.com/erik78se/loki-vm-operator/
- promtail: https://github.com/erik78se/promtail-vm-operator/
Here is a screenshot of what you will see.
Anyone can join. No prior knowledge needed. Bring a friend.
