Command 'upgrade-machine'
See also: machines, status, refresh, set-application-base
Upgrade the Ubuntu base of a machine.
Usage
juju upgrade-machine [options] <machine> <command> [args]
Options
Flag Default Usage
--B, --no-browser-login false Do not use web browser for authentication
--force false Upgrade even if the base is not supported by the charm and/or related subordinate charms.
--m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--y, --yes false Agree that the operation cannot be reverted or canceled once started without being prompted.
Examples
Prepare machine 3 for upgrade to base “ubuntu@18.04"”:
juju upgrade-machine 3 prepare ubuntu@18.04
Prepare machine 4 for upgrade to base “ubuntu@20.04” even if there are applications running units that do not support the target base:
juju upgrade-machine 4 prepare ubuntu@20.04 --force
Complete upgrade of machine 5, indicating that all automatic and any necessary manual upgrade steps have completed successfully:
juju upgrade-machine 5 complete
Details
Upgrade a machine’s operating system release.
upgrade-machine allows users to perform a managed upgrade of the operating system release of a machine using a base. This command is performed in two steps; prepare and complete.
The “prepare” step notifies Juju that a base upgrade is taking place for a given machine and as such Juju guards that machine against operations that would interfere with the upgrade process. A base can be specified using the OS name and the version of the OS, separated by @.
The “complete” step notifies juju that the managed upgrade has been successfully completed.
It should be noted that once the prepare command is issued there is no way to cancel or abort the process. Once you commit to prepare you must complete the process or you will end up with an unusable machine!
The requested base must be explicitly supported by all charms deployed to the specified machine. To override this constraint the --force option may be used.
The --force option should be used with caution since using a charm on a machine running an unsupported base may cause unexpected behavior. Alternately, if the requested base is supported in later revisions of the charm, upgrade-charm can run beforehand.
