See also: add-k8s, remove-k8s
Updates an existing k8s endpoint used by Juju.
Usage
juju update-k8s [options] <k8s name>
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--c, --controller |
Controller to operate in | |
--client |
false | Client operation |
--f |
The path to a cloud definition file |
Examples
juju update-k8s microk8s
juju update-k8s myk8s -f path/to/k8s.yaml
juju update-k8s myk8s -f path/to/k8s.yaml --controller mycontroller
juju update-k8s myk8s --controller mycontroller
juju update-k8s myk8s --client --controller mycontroller
juju update-k8s myk8s --client -f path/to/k8s.yaml
Details
Update k8s cloud information on this client and/or on a controller.
The k8s cloud can be a built-in cloud like microk8s.
A k8s cloud can also be updated from a file. This requires a <cloud name> and a yaml file containing the cloud details.
A k8s cloud on the controller can also be updated just by using a name of a k8s cloud from this client.
Use --controller option to update a k8s cloud on a controller.
Use --client to update a k8s cloud definition on this client.
