Command 'sync-agent-binary'
See also: upgrade-controller
Copy agent binaries from the official agent store into a local controller.
Options
Flag Default Usage
--B, --no-browser-login false Do not use web browser for authentication
--agent-version Copy a specific major[.minor] version
--dry-run false Don’t copy, just print what would be copied
--local-dir Local destination directory
--m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--public false Tools are for a public cloud, so generate mirrors information
--source Local source directory
--stream Simplestreams stream for which to sync metadata
Examples
juju sync-agent-binary --debug --agent-version 2.0
juju sync-agent-binary --debug --agent-version 2.0 --local-dir=/home/ubuntu/sync-agent-binary
Details
This copies the Juju agent software from the official agent binaries store (located at Index of /juju) into the controller. It is generally done when the controller is without Internet access.
Instead of the above site, a local directory can be specified as source. The online store will, of course, need to be contacted at some point to get the software.
