List storage pools.
Options
| Flag | Default | Usage |
--B, --no-browser-login
--format |
tabular | Specify output format (json|tabular|yaml) |
--m, --model
--name |
Only show pools with these names | |
--o, --output
Specify an output file | |
--provider |
Only show pools of these provider types |
Details
The user can filter on pool type, name.
If no filter is specified, all current pools are listed. If at least 1 name and type is specified, only pools that match both a name AND a type from criteria are listed. If only names are specified, only mentioned pools will be listed. If only types are specified, all pools of the specified types will be listed.
Both pool types and names must be valid. Valid pool types are pool types that are registered for Juju model.
