See also: run, operations, show-task
Show results of an operation.
Usage
juju show-operation [options] <operation-id>
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--format |
yaml | Specify output format (json|yaml) |
--m, --model |
--o, --output |
Specify an output file | |
--utc |
false | Show times in UTC |
--wait |
-1s | Wait for results |
--watch |
false | Wait indefinitely for results |
Examples
juju show-operation 1
juju show-operation 1 --wait=2m
juju show-operation 1 --watch
Details
Show the results returned by an operation with the given ID.
To block until the result is known completed or failed, use
the --wait option with a duration, as in --wait 5s or --wait 1h.
Use --watch to wait indefinitely.
The default behavior without --wait or --watch is to immediately check and return; if the results are “pending” then only the available information will be displayed. This is also the behavior when any negative time is given.
