See also: credentials, add-credential, remove-credential, autoload-credentials Alias: default-credential
Sets local default credentials for a cloud on this client.
Usage
juju default-credential [options] <cloud name> [<credential name>]
Options
| Flag | Default | Usage |
--reset |
false | Reset default credential for the cloud |
Examples
juju default-credential google credential_name
juju default-credential google --reset
Details
The default credentials are specified with a “credential name”.
A credential name is created during the process of adding credentials either
via juju add-credential or juju autoload-credentials.
Credential names can be listed with juju credentials.
This command sets a locally stored credential to be used as a default. Default credentials avoid the need to specify a particular set of credentials when more than one are available for a given cloud.
To unset previously set default credential for a cloud, use --reset option.
To view currently set default credential for a cloud, use the command without a credential name argument.
