See also: status, refresh, upgrade-machine
Set an application’s base.
Usage
juju set-application-base [options] <application> <base>
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--m, --model |
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID> |
Examples
Set the base for the ubuntu application to ubuntu@20.04:
juju set-application-base ubuntu ubuntu@20.04
Details
The specified application’s base value will be set within juju. Any subordinates of the application will also have their base set to the provided value. A base can be specified using the OS name and the version of the OS, separated by @.
This will not change the base of any existing units, rather new units will use the new base when deployed.
It is recommended to only do this after upgrade-machine has been run for machine containing all existing units of the application.
To ensure correct binaries, run ‘juju refresh’ before running ‘juju add-unit’.
