See also: add-space, spaces, reload-spaces, rename-space, show-space
Remove a network space.
Usage
juju remove-space [options] <name>
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--force |
false | remove the offer as well as any relations to the offer |
--m, --model |
--y, --yes |
false | Do not prompt for confirmation |
Examples
Remove a space by name:
juju remove-space db-space
Remove a space by name with force, without need for confirmation:
juju remove-space db-space --force -y
Details
Removes an existing Juju network space with the given name. Any subnets associated with the space will be transferred to the default space. The command will fail if existing constraints, bindings or controller settings are bound to the given space.
If the --force option is specified, the space will be deleted even if there are existing bindings, constraints or settings.
