Display status information about known payloads.
Usage
juju payloads [options] [pattern ...]
Options
| Flag | Default | Usage |
--B, --no-browser-login
--format |
tabular | Specify output format (json|tabular|yaml) |
--m, --model
--o, --output
Specify an output file |
Details
This command will report on the runtime state of defined payloads.
When one or more pattern is given, Juju will limit the results to only those payloads which match any of the provided patterns. Each pattern will be checked against the following info in Juju:
- unit name
- machine id
- payload type
- payload class
- payload id
- payload tag
- payload status
