See also: change-user-password, login
Logs a Juju user out of a controller.
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--c, --controller |
Controller to operate in | |
--force |
false | Force logout when a locally recorded password is detected |
Examples
juju logout
Details
If another client has logged in as the same user, they will remain logged in. This command only affects the local client.
The command will fail if the user has not yet set a password
(juju change-user-password). This scenario is only possible after
juju bootstrapsince juju register sets a password. The
failing behaviour can be overridden with the ‘–force’ option.
If the same user is logged in with another client system, that user session will not be affected by this command; it only affects the local client.
By default, the controller is the current controller.
