Command 'list-charm-resources'
Alias: charm-resources
Display the resources for a charm in a repository.
Usage
juju charm-resources [options] <charm>
Options
Flag Default Usage
--B, --no-browser-login false Do not use web browser for authentication
--channel stable the channel of the charm
--format tabular Specify output format (json|tabular|yaml)
--m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--o, --output Specify an output file
Examples
Display charm resources for the postgresql charm:
juju charm-resources postgresql
Display charm resources for mycharm in the 2.0/edge channel:
juju charm-resources mycharm --channel 2.0/edge
Details
This command will report the resources and the current revision of each resource for a charm in a repository.
<charm> can be a charm URL, or an unambiguously condensed form of it, just like the deploy command.
Release is implied from the <charm> supplied. If not provided, the default series for the model is used.
Channel can be specified with --channel. If not provided, stable is used.
Where a channel is not supplied, stable is used.
