The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: [wait-for model](wait-for model), [wait-for machine](wait-for machine), [wait-for unit](wait-for unit)
Wait for an application to reach a specified state.
Usage
juju wait-for application [options] [<name>]
Options
Flag | Default | Usage |
-B , --no-browser-login |
-m , --model |
--query |
life==“alive” && status==“active” | query the goal state |
--summary |
true | output a summary of the application query on exit |
--timeout |
10m0s | how long to wait, before timing out |
Examples
Waits for 4 units to be present.
juju wait-for application ubuntu --query='len(units) == 4'
Waits for all the application units to start with ubuntu and to be created and available.
juju wait-for application ubuntu --query='forEach(units, unit => unit.life=="alive" && unit.status=="available" && startsWith(unit.name, "ubuntu"))'
Details
The wait-for application command waits for the application to reach a goal state. The goal state can be defined programmatically using the query DSL (domain specific language). The default query for an application just waits for the application to be created and active.
The wait-for command is an optimized alternative to the status command for determining programmatically if a goal state has been reached. The wait-for command streams delta changes from the underlying database, unlike the status command which performs a full query of the database.
The application query DSL can be used to programmatically define the goal state for machines and units within the scope of the application. This can be achieved by using lambda expressions to iterate over the machines and units associated with the application. Multiple expressions can be combined to define a complex goal state.
