The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: sync-agent-binary
Upgrades Juju on all machines in a model.
Options
Flag | Default | Usage |
-B , --no-browser-login |
--agent-stream |
Check this agent stream for upgrades | |
--agent-version |
Upgrade to specific version | |
--dry-run |
false | Don’t change anything, just report what would be changed |
--ignore-agent-versions |
false | Don’t check if all agents have already reached the current version |
-m , --model |
--reset-previous-upgrade |
false | Clear the previous (incomplete) upgrade status (use with care) |
--timeout |
10m0s | Timeout before upgrade is aborted |
-y , --yes |
false | Answer ‘yes’ to confirmation prompts |
Examples
juju upgrade-model --dry-run
juju upgrade-model --agent-version 2.0.1
juju upgrade-model --agent-stream proposed
Details
Juju provides agent software to every machine it creates. This command
upgrades that software across an entire model, which is, by default, the
current model.
A model’s agent version can be shown with juju model-config agent-version
A version is denoted by: major.minor.patch
If ‘–agent-version’ is not specified, then the upgrade candidate is selected to be the exact version the controller itself is running.
If the controller is without internet access, the client must first supply
the software to the controller’s cache via the juju sync-agent-binary
command.
The command will abort if an upgrade is in progress. It will also abort if
a previous upgrade was not fully completed (e.g.: if one of the
controllers in a high availability model failed to upgrade).
When looking for an agent to upgrade to, Juju will check the currently configured agent stream for that model. It’s possible to overwrite this for the lifetime of this upgrade using --agent-stream
If a failed upgrade has been resolved, ‘–reset-previous-upgrade’ can be used to allow the upgrade to proceed. Backups are recommended prior to upgrading.
