The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
Update an existing secret.
Usage
juju update-secret [options] <ID>|<name> [key[#base64|#file]=value...]
Options
Flag | Default | Usage |
--auto-prune |
nil | used to allow Juju to automatically remove revisions which are no longer being tracked by any observers |
--file |
a YAML file containing secret key values | |
--info |
the secret description | |
-m , --model |
--name |
the new secret name |
Examples
juju update-secret secret:9m4e2mr0ui3e8a215n4g token=34ae35facd4
juju update-secret secret:9m4e2mr0ui3e8a215n4g key#base64 AA==
juju update-secret secret:9m4e2mr0ui3e8a215n4g token=34ae35facd4 --auto-prune
juju update-secret secret:9m4e2mr0ui3e8a215n4g --name db-password \
--info "my database password" \
data#base64 s3cret==
juju update-secret db-pass --name db-password \
--file=/path/to/file
Details
Update a secret with a list of key values, or info. If a value has the ‘#base64’ suffix, it is already in base64 format and no encoding will be performed, otherwise the value will be base64 encoded prior to being stored. The --auto-prune option is used to allow Juju to automatically remove revisions which are no longer being tracked by any observers (see Rotation and Expiry). This is configured per revision. This feature is opt-in because Juju automatically removing secret content might result in data loss.
