Command 'juju update-k8s'
The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: add-k8s, remove-k8s
Updates an existing k8s endpoint used by Juju.
Usage
juju update-k8s [options] <k8s name>
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
-c, --controller Controller to operate in
--client false Client operation
-f The path to a cloud definition file
Examples
juju update-k8s microk8s
juju update-k8s myk8s -f path/to/k8s.yaml
juju update-k8s myk8s -f path/to/k8s.yaml --controller mycontroller
juju update-k8s myk8s --controller mycontroller
juju update-k8s myk8s --client --controller mycontroller
juju update-k8s myk8s --client -f path/to/k8s.yaml
Details
Update k8s cloud information on this client and/or on a controller.
The k8s cloud can be a built-in cloud like microk8s.
A k8s cloud can also be updated from a file. This requires a <cloud name> and a yaml file containing the cloud details.
A k8s cloud on the controller can also be updated just by using a name of a k8s cloud from this client.
Use --controller option to update a k8s cloud on a controller.
Use --client to update a k8s cloud definition on this client.
