The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
See also: add-secret-backend, secret-backends, show-secret-backend, update-secret-backend
Removes a secret backend from the controller.
Usage
juju remove-secret-backend [options] <backend-name>
Options
Flag | Default | Usage |
-c , --controller |
Controller to operate in | |
--force |
false | force removal even if the backend stores in-use secrets |
Examples
juju remove-secret-backend myvault
juju remove-secret-backend myvault --force
Details
Removes a secret backend, used for storing secret content. If the backend is being used to store secrets currently in use, the --force option can be supplied to force the removal, but be warned, this will affect charms which use those secrets.
