Command 'juju register'
The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: add-user, change-user-password, unregister
Registers a controller.
Usage
juju register [options] <registration string>|<controller host name>
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--replace false replace any existing controller
Examples
juju register MFATA3JvZDAnExMxMDQuMTU0LjQyLjQ0OjE3MDcwExAxMC4xMjguMC4yOjE3MDcwBCBEFCaXerhNImkKKabuX5ULWf2Bp4AzPNJEbXVWgraLrAA=
juju register --replace MFATA3JvZDAnExMxMDQuMTU0LjQyLjQ0OjE3MDcwExAxMC4xMjguMC4yOjE3MDcwBCBEFCaXerhNImkKKabuX5ULWf2Bp4AzPNJEbXVWgraLrAA=
juju register public-controller.example.com
Details
The register command adds details of a controller to the local system. This is done either by completing the user registration process that began with the ‘juju add-user’ command, or by providing the DNS host name of a public controller.
To complete the user registration process, you should have been provided with a base64-encoded blob of data (the output of ‘juju add-user’) which can be copied and pasted as the <string> argument to ‘register’. You will be prompted for a password, which, once set, causes the registration string to be voided. In order to start using Juju the user can now either add a model or wait for a model to be shared with them. Some machine providers will require the user to be in possession of certain credentials in order to add a model.
If a new controller has been spun up to replace an existing one, and you want to start using that replacement controller instead of the original one, use the --replace option to overwrite any existing controller details based on either a name or UUID match.
When adding a controller at a public address, authentication via some external third party (for example Ubuntu SSO) will be required, usually by using a web browser.
