Command 'juju logout'
The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
See also: change-user-password, login
Logs a Juju user out of a controller.
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
-c, --controller Controller to operate in
--force false Force logout when a locally recorded password is detected
Examples
juju logout
Details
If another client has logged in as the same user, they will remain logged in. This command only affects the local client.
The command will fail if the user has not yet set a password (juju change-user-password). This scenario is only possible after juju bootstrapsince juju register sets a password. The failing behaviour can be overridden with the ‘–force’ option.
If the same user is logged in with another client system, that user session will not be affected by this command; it only affects the local client.
By default, the controller is the current controller.
