Command 'juju list-storage-pools'
The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: create-storage-pool, remove-storage-pool Alias: storage-pools
List storage pools.
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--format tabular Specify output format (json|tabular|yaml)
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--name Only show pools with these names
-o, --output Specify an output file
--provider Only show pools of these provider types
Examples
List all storage pools:
juju storage-pools
List only pools of type kubernetes, azure, ebs:
juju storage-pools --provider kubernetes,azure,ebs
List only pools named pool1 and pool2:
juju storage-pools --name pool1,pool2
Details
The user can filter on pool type, name.
If no filter is specified, all current pools are listed. If at least 1 name and type is specified, only pools that match both a name AND a type from criteria are listed. If only names are specified, only mentioned pools will be listed. If only types are specified, all pools of the specified types will be listed.
Both pool types and names must be valid. Valid pool types are pool types that are registered for Juju model.
