Command 'juju export-bundle'
The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
Exports the current model configuration as a reusable bundle.
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--filename Bundle file
--include-charm-defaults false Whether to include charm config default values in the exported bundle
--include-series false Comaptibility option. Set to include series in the bundle alongside bases
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
Examples
juju export-bundle
juju export-bundle --filename mymodel.yaml
juju export-bundle --include-charm-defaults
juju export-bundle --include-series
Details
If --filename is not used, the configuration is printed to stdout. –filename specifies an output file.
If --include-series is used, the exported bundle will include the OS series alongside bases. This should be used as a compatibility option for older versions of Juju before bases were added.
